Console Resource Management
Nacos engines support the association between namespaces and enterprise projects. The relationship is N:1, that is, N namespaces can be associated with one enterprise project.
By default, the namespace created in Creating a Namespace is not associated with any enterprise project. You can associate the namespace with an enterprise project by editing the enterprise project.
When editing an enterprise project, you can only change the enterprise project and cannot leave the enterprise project empty.
- Log in to CSE.
- In the left navigation pane, choose Registry/Configuration Center.
- Click the target Nacos engine.
- Choose Permission Control.
- On the Console Resource Management tab, click
in the Enterprise Project column of the target namespace. In the Edit Enterprise Project dialog box, select an enterprise project from the drop-down list and click OK.
Feedback
Was this page helpful?
Chatbot
