Help Center/
Data Lake Insight/
SQL Syntax Reference (Paris Region)/
Spark SQL Syntax Reference/
Built-in Functions/
Date Functions/
weekday
Updated on 2025-01-22 GMT+08:00
weekday
This function is used to return the day of the current week.
Syntax
weekday (string date)
Parameters
Parameter |
Mandatory |
Type |
Description |
date |
Yes |
DATE or STRING |
Date that needs to be processed
The following formats are supported:
Return Values
The return value is of the INT type.
- If Monday is used as the first day of a week, the value 0 is returned. For other weekdays, the return value increases in ascending order. For Sunday, the value 6 is returned.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
Example Code
The value 2 is returned.
select weekday ('2023-08-16 10:54:36');
The value NULL is returned.
select weekday (null);
Parent topic: Date Functions
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
