Updated on 2025-01-22 GMT+08:00
cot1
This function is used to calculate the cotangent value of a, with input in radians.
Syntax
cot1(DOUBLE a)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE or DECIMAL type.
If the value of a is NULL, NULL is returned.
Example Code
The value 1.0000000000000002 is returned.
select cot1(pi()/4);
The value NULL is returned.
select cot1(null);
