Updated on 2025-01-22 GMT+08:00
sqrt
This function is used to return the square root of a value.
Syntax
sqrt(DOUBLE a)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value 2.8284271247461903 is returned.
select sqrt(8);
The value 4 is returned.
select sqrt(16);
The value NULL is returned.
select sqrt(null);
