Help Center/ Object Storage Service/ SDK Reference/ Android/ Versioning Management/ Setting Versioning Status for a Bucket
Updated on 2024-06-21 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.setBucketVersioning to set the versioning status for a bucket. OBS supports two versioning statuses.
Versioning Status
Description
Value in OBS Android SDK
Enabled
  1. OBS creates a unique version ID for each uploaded object. Namesake objects are not overwritten and are distinguished by their own version IDs.
  2. Objects can be downloaded by specifying the version ID. By default, the object of the latest version is downloaded if no version ID is specified.
  3. Objects can be deleted by specifying the version ID. If an object is deleted with no version ID specified, the object will generate a delete marker with a unique version ID but is not physically deleted.
  4. The latest objects in a bucket are returned by default after ObsClient.listObjects is called. You can call ObsClient.listVersions to list a bucket's objects with all version IDs.
  5. Except for delete markers, storage space occupied by objects with all version IDs is billed.
VersioningStatusEnum.ENABLED
Suspended
  1. Noncurrent object versions are not affected.
  2. OBS creates version ID null to an uploaded object and the object will be overwritten after a namesake one is uploaded.
  3. Objects can be downloaded by specifying the version ID. By default, the object of the latest version is downloaded if no version ID is specified.
  4. Objects can be deleted by specifying version IDs. If an object is deleted with no version ID specified, the object is only attached with a delete marker whose version ID is null. Objects with version ID null are physically deleted.
VersioningStatusEnum.SUSPENDED
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
// Enable versioning.
obsClient.setBucketVersioning("bucketname", new BucketVersioningConfiguration(VersioningStatusEnum.ENABLED));
// Suspend versioning.
obsClient.setBucketVersioning("bucketname", new BucketVersioningConfiguration(VersioningStatusEnum.SUSPENDED));
