Updated on 2025-05-16 GMT+08:00
Downloading an Object (SDK for C)
This example shows how to download an object from a bucket to a directory and save the object as test.
Sample code:
static void test_get_object()
    char *file_name = "./test";
    obs_object_info object_info;
    // Initialize option.
    obs_options option;
    init_obs_options(&option);
    option.bucket_options.host_name = "<your-endpoint>";
    option.bucket_options.bucket_name = "<Your bucketname>";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    option.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    option.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    // Set the object to be downloaded.
    memset(&object_info, 0, sizeof(obs_object_info));
    object_info.key = "<object key>";
    object_info.version_id = "<object version ID>";
    // Customize the structure for storing downloaded object data based on service requirements.
    get_object_callback_data data;
    data.ret_status = OBS_STATUS_BUTT;
    data.outfile = write_to_file(file_name);
    // Define range download parameters.
    obs_get_conditions getcondition;
    memset(&getcondition, 0, sizeof(obs_get_conditions));
    init_get_properties(&getcondition);
    // Customize callback function for download.
    obs_get_object_handler get_object_handler =
        { &response_properties_callback, &get_object_complete_callback},
        &get_object_data_callback
    get_object(&option, &object_info, &getcondition, 0, &get_object_handler, &data);
    if (OBS_STATUS_OK == data.ret_status) {
        printf("get object successfully. \n");
    else
        printf("get object failed(%s).\n", obs_get_status_name(data.ret_status));
    fclose(data.outfile);
For more information, see Downloading an Object (SDK for C).
