Help Center/
Object Storage Service/
SDK Reference/
C/
Getting Started (SDK for C)/
Listing Objects (SDK for C)
Updated on 2025-05-16 GMT+08:00
This example shows how to list all objects in a bucket.
Sample code:
static void test_list_bucket_objects() { // Create and initialize option. obs_options option; init_obs_options(&option); option.bucket_options.host_name = "<your-endpoint>"; option.bucket_options.bucket_name = "<Your bucketname>"; // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. option.bucket_options.access_key = getenv("ACCESS_KEY_ID"); option.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY"); // Set response callback function. obs_list_objects_handler list_bucket_objects_handler = { { &response_properties_callback, &list_objects_complete_callback }, &list_objects_callback }; // Customize callback data. list_bucket_callback_data data; memset(&data, 0, sizeof(list_bucket_callback_data)); // List objects. list_bucket_objects(&option, "<prefix>", "<marker>", "<delimiter>", "<maxkeys>", &list_bucket_objects_handler, &data); if (OBS_STATUS_OK == data.ret_status) { printf("list bucket objects successfully. \n"); } else { printf("list bucket objects failed(%s).\n", obs_get_status_name(data.ret_status)); } }
Parent topic: Getting Started (SDK for C)
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
