Help Center/
Object Storage Service/
SDK Reference/
.NET/
Object Management/
Obtaining Object Properties
Updated on 2024-12-09 GMT+08:00
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.GetObjectMetadata to obtain object properties, including the last modification time, version ID, and customized metadata. Sample code is as follows:
// Initialize configuration parameters. ObsConfig config = new ObsConfig(); config.Endpoint = "https://your-endpoint"; // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine); string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine); // Create an instance of ObsClient. ObsClient client = new ObsClient(accessKey, secretKey, config); try { GetObjectMetadataRequest request = new GetObjectMetadataRequest(); // Specify a bucket name. request.BucketName = "bucketname"; // Specify an object (example/objectname as an example). request.ObjectKey = "example/objectname"; // Obtain the object metadata. using (GetObjectMetadataResponse response = client.GetObjectMetadata(request)) { Console.WriteLine("Get object metadata response: {0}", response.StatusCode); // Obtain ETag of the object. Console.WriteLine("Object etag {0}: ", response.ETag); // Obtain the object version ID. Console.WriteLine("Object versionId {0}: ", response.VersionId); // Obtain the length of the object data, in bytes. Console.WriteLine("Object contentLength {0}: ", response.ContentLength); } } catch (ObsException ex) { Console.WriteLine("Message: {0}", ex.Message); }
- Due to HTTP coding restrictions, non-ASCII characters cannot be sent. The SDK will decode the information in response headers using URL decoding rules.
Parent topic: Object Management
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
