Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Configuring CORS for a Bucket (SDK for Go)
Updated on 2024-06-21 GMT+08:00
Function
Cross-origin resource sharing (CORS) is a browser-standard mechanism defined by the World Wide Web Consortium (W3C). It allows a web client in one origin to interact with resources in another one. For general web page requests, website scripts and contents in one origin cannot interact with those in another because of Same Origin Policies (SOPs). OBS supports CORS rules that allow the resources in OBS to be requested from other origins.
This API configures CORS for a bucket.
Restrictions
Method
func (obsClient ObsClient) SetBucketCors(input *SetBucketCorsInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
*SetBucketCorsInput
Yes
Explanation:
Input parameters for configuring CORS for a bucket. For details, see Table 2.
Table 2 SetBucketCorsInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
CorsRules
[]CorsRule
Yes
Explanation:
CORS rule list of the bucket. For details, see Table 3.
Restrictions:
A list can have a maximum of 100 CORS rules.
Table 3 CorsRule
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
No if used as a request parameter
Explanation:
CORS rule ID
Value range:
The value must contain 1 to 255 characters.
Default value:
None
AllowedMethod
[]string
Yes if used as a request parameter
Explanation:
The allowed HTTP methods cross-origin request, same as the operation types of buckets and objects.
Value range:
The following HTTP methods are supported:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
AllowedOrigin
[]string
Explanation:
The origin from which the requests can access the bucket.
Restrictions:
Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com.
Default value:
None
AllowedHeader
[]string
Explanation:
The allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid.
Restrictions:
Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
MaxAgeSeconds
int
Explanation:
Time your client can cache the response for a cross-origin request
Restrictions:
Each CORS rule can specify only one value for MaxAgeSeconds.
Value range:
0 to (231 – 1), in seconds
Default value:
100
ExposeHeader
[]string
Explanation:
The CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers.
Restrictions:
Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
Responses
Table 4 List of returned results
Parameter
Type
Description
output
*BaseModel
Explanation:
Returned results. For details, see Table 5.
err
error
Explanation:
Error messages returned by the API
Table 5 BaseModel
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Code Examples
This example configures CORS rules for bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetBucketCorsInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify CORS rules.
    input.CorsRules = []obs.CorsRule{
            AllowedOrigin: []string{"http://www.a.com", "http://www.b.com"},
            AllowedMethod: []string{"GET", "PUT"},
            AllowedHeader: []string{"header1", "header2"},
            MaxAgeSeconds: 1000,
            ExposeHeader:  []string{"obs-1", "obs-2"},
            AllowedOrigin: []string{"http://www.c.com", "http://www.d.com"},
            AllowedMethod: []string{"GET", "POST"},
            AllowedHeader: []string{"header3", "header4"},
    // Configure CORS for the bucket.
    output, err := obsClient.SetBucketCors(input)
    if err == nil {
        fmt.Printf("Set bucket(%s) CORS configuration successful!\n", input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Set bucket(%s) CORS configuration fail!\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
