Obtaining the Bucket Encryption Configuration (SDK for Go)
Function
After you enable encryption for a bucket, the objects you upload to this bucket will be encrypted with the specified encryption method before they are stored in OBS. When you later download these encrypted objects, OBS decrypts them first and then returns them to you.
This API returns the encryption configuration of a bucket.
Restrictions
- To obtain the encryption configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetEncryptionConfiguration in IAM or GetEncryptionConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) GetBucketEncryption(bucketName string) (output *GetBucketEncryptionOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
string |
Yes |
Explanation: Bucket name Restrictions:
Value range: The value must contain 3 to 63 characters. |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 3. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
SSEAlgorithm |
string |
Explanation: Objects are encrypted using SSE-KMS on the server side. Value range: kms Default value: None |
KMSMasterKeyID |
string |
Explanation: ID of the KMS master key used for SSE-KMS Value range: Valid value formats are as follows:
In the preceding formats:
Default value: If this parameter is not specified, the default master key will be used. |
ProjectID |
string |
Explanation: ID of the project where the KMS master key belongs in SSE-KMS Restrictions:
Value range: To obtain the enterprise project ID, see How Do I Obtain a Project ID?. Default value: None |
Code Examples
This example returns the encryption configuration of bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Specify a bucket name. bucketname := "examplebucket" // Obtain the encryption configuration of the bucket. output, err := obsClient.GetBucketEncryption(bucketname) if err == nil { fmt.Printf("Get bucket(%s)'s encryption configuration successful!\n", bucketname) fmt.Printf("RequestId:%s\n", output.RequestId) fmt.Printf("Encryption:%s\n", output.SSEAlgorithm) fmt.Printf("KeyID:%s\n", output.KMSMasterKeyID) return } fmt.Printf("Get bucket(%s)'s encryption configuration fail!\n", bucketname) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
