Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Object Download (SDK for Node.js)/ Downloading an Object - Streaming (SDK for Node.js)
Updated on 2025-02-07 GMT+08:00
Function
This API downloads an object as a stream from OBS to your local computer.
Restrictions
Method
ObsClient.getObject(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9A
Restrictions:
None
Value range:
The value must contain 32 characters.
Default value:
None
SaveAsFile
string
No
Explanation:
The download path with the file name contained
Restrictions:
A file name must be included in the path, for example, aa/bb.txt.
Value range:
None
Default value:
None
SaveAsStream
boolean
No
Explanation:
Whether the object is returned as a readable stream
Value range:
  • true: The object is returned as a readable stream.
  • false: The object is not returned as a readable stream.
Default value:
false
ProgressCallback
function
No
Explanation:
Callback function for obtaining the download progress
NOTE:
This callback function contains the following parameters in sequence: number of downloaded bytes, total bytes, and used time (unit: second).
Restrictions:
None
Value range:
None
Default value:
None
IfMatch
string
No
Explanation:
Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned.
Restrictions:
None
Value range:
Default value:
None
IfModifiedSince
string
No
Explanation:
If the object was modified after the time specified by this parameter, its content is returned. Otherwise, an error code is returned.
Restrictions:
The value must conform with the HTTP time format specified in http://www.ietf.org/rfc/rfc2616.txt.
Value range:
None
Default value:
None
IfNoneMatch
string
No
Explanation:
Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned.
Restrictions:
None
Value range:
Default value:
None
IfUnmodifiedSince
string
No
Explanation:
If the object was modified before the time specified by this parameter, its content is returned. Otherwise, an error code is returned.
Restrictions:
Value range:
None
Default value:
None
Range
string
No
Explanation:
Download range. For example, 0-999 indicates the range is from byte 1 to byte 1000.
Restrictions:
The maximum length of Range is the length of the object minus 1. If the specified value exceeds this limit, the length of the object minus 1 is used.
Value range:
0 to the object length minus 1. Format: bytes=x-y
Default value:
None
Origin
string
No
Explanation:
Origin of the cross-domain request specified in the preflight request. It is usually a domain name.
Restrictions:
Each origin can contain at most one wildcard character (*).
Value range:
None
Default value:
None
RequestHeader
string
No
Explanation:
HTTP headers that can be used in cross-origin requests. Only CORS requests matching the allowed headers are valid.
Restrictions:
Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
None
Default value:
None
ResponseCacheControl
string
No
Explanation:
This parameter is used to rewrite the Cache-Control header in the response.
Restrictions:
None
Value range:
See the Cache-Control values defined in HTTP.
Default value:
None
ResponseContentDisposition
string
No
Explanation:
This parameter is used to rewrite the Content-Disposition header in the response.
Restrictions:
None
Value range:
See the Content-Disposition values defined in HTTP.
Default value:
None
ResponseContentEncoding
string
No
Explanation:
This parameter is used to rewrite the Content-Encoding header in the response.
Restrictions:
None
Value range:
See the Content-Encoding values defined in HTTP.
Default value:
None
ResponseContentLanguage
string
No
Explanation:
This parameter is used to rewrite the Content-Language header in the response.
Restrictions:
None
Value range:
See the Content-Language values defined in HTTP.
Default value:
None
ResponseContentType
string
No
Explanation:
This parameter is used to rewrite the Content-Type header in the response.
Restrictions:
None
Value range:
See What Is Content-Type (MIME)? (SDK for Node.js)
Default value:
None
ResponseExpires
string
No
Explanation:
This parameter is used to rewrite the Expires header in the response.
Restrictions:
None
Value range:
See the Expires values defined in HTTP.
Default value:
None
ImageProcess
string
No
Explanation:
Image processing command or style. Example for resizing and rotating an image: image/resize,m_fixed,w_100,h_100/rotate,90
Restrictions:
None
Value range:
Command format: image/commands
Style format: style/style-name
For details about image processing parameters, see Processing Images.
Default value:
If no commands are entered, the original image is returned.
SseC
string
Yes when SSE-C is used
Explanation:
SSE-C is used for decrypting objects.
Restrictions:
Only AES256 is supported.
Value range:
AES256
Default value:
None
SseCKey
string
Explanation:
Key used for decrypting objects when SSE-C is used
Restrictions:
A Base64-encoded, 256-bit value, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=
Value range:
None
Default value:
None
  • If a download request includes IfUnmodifiedSince or IfMatch but does not meet the conditions specified by these parameters, an exception is thrown with HTTP status code 412 Precondition Failed.
  • If a download request includes IfModifiedSince or IfNoneMatch but does not meet the conditions specified by these parameters, an exception is thrown with HTTP status code 304 Not Modified.
Responses
Table 2 Responses
Type
Description
Table 3
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results outputted for a successful call. For details, see Table 5.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 4 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 GetObjectOutput
Parameter
Type
Description
RequestId
string
Explanation:
DeleteMarker
string
Explanation:
Whether the deleted object is a delete marker.
LastModified
string
Explanation:
Time when the object was last modified.
ContentLength
string
Explanation:
Object size
CacheControl
string
Explanation:
ContentDisposition
string
Explanation:
ContentEncoding
string
Explanation:
ContentLanguage
string
Explanation:
ContentType
string
Explanation:
MIME type of the object.
Expires
string
Explanation:
ETag
string
Explanation:
ETag of the object.
VersionId
string
Explanation:
Object version ID
WebsiteRedirectLocation
string
Explanation:
Location where an object is redirected. It is available when website hosting is configured for a bucket.
StorageClass
string
Explanation:
Object storage class. If the storage class is Standard, this parameter is left blank.
Restore
string
Explanation:
Restoration status of the object in the Archive storage class
Expiration
string
Explanation:
Expiration details
Content
string |
stream.Readable
Explanation:
Content of the object. The content is left blank if SaveAsFile was specified. The content is a stream.Readable object if SaveAsStream was set to true. The content is a Buffer object if neither SaveAsFile nor SaveAsStream was specified.
Metadata
object
Explanation:
Custom metadata of the object. You need to add in the CORS configurations the additional headers allowed to be carried in the response. For example, you can add the x-amz-meta-property1 header to allow custom metadata property1 to be returned.
Code Examples
This example downloads object examplebucket/objectname using the stream.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function getObject() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify the object to download (example/objectname in this example).
      Key: 'example/objectname',
      // Specify that the object is returned as a stream (stream.Readable).
      SaveAsStream: true
    // Download the object using the stream.
    const result = await obsClient.getObject(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Get object(%s) under the bucket(%s) successful!", params.Key, params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      console.log('Object Content:');
      result.InterfaceResult.Content.on('data', (data) => {
        console.log(data.toString());
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
getObject();
