Obtaining the ACL of an Object (SDK for Node.js)
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources.
For more information, see ACLs.
This API returns the ACL of an object.
Restrictions
- To obtain an object ACL, you must be the bucket owner or have the required permission (obs:object:GetObjectAcl in IAM or GetObjectAcl in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
Method
ObsClient.getObjectAcl(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Key |
string |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
VersionId |
string |
No |
Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9A Restrictions: None Value range: The value must contain 32 characters. Default value: None |
Responses
Type |
Description |
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 3. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Parameter |
Type |
Description |
RequestId |
string |
Explanation: Request ID returned by the OBS server |
VersionId |
string |
Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9A |
Owner |
Explanation: Object owner. For details, see Owner. |
Delivered |
string |
Explanation: Whether the bucket ACL is applied to the objects in the bucket. |
Grants |
Grant[] |
Explanation: Grantees' permission information. For details, see Table 7. |
Parameter |
Type |
Description |
ID |
string |
Yes if used as a request parameter |
Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (SDK for Node.js). Default value: None |
DisplayName |
string |
No |
Explanation: Account name of the owner Default value: None |
Parameter |
Type |
Description |
Grantee |
Explanation: Grantee information. For details, see Table 8. |
Permission |
Explanation: Granted permission Value range: See Table 11. |
Parameter |
Type |
Description |
Type |
string |
Explanation: Grantee type Value range: See Table 9. Default value: None |
ID |
string |
Yes if this parameter is used as a request parameter and Type is set to a user |
Explanation: Account (domain) ID of the grantee. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (SDK for Node.js). Default value: None |
Name |
string |
No if used as a request parameter |
Explanation: Account name of the grantee. Restrictions:
URI |
Yes if this parameter is used as a request parameter and Type is set to a group |
Explanation: Authorized user group Value range: See Table 10. Default value: None |
Constant |
Description |
Group |
Grants permissions to user groups. |
CanonicalUser |
Grants permissions to individual users. |
Constant |
Default Value |
Description |
ObsClient.enums.GroupAllUsers |
AllUsers |
All users. |
ObsClient.enums.GroupAuthenticatedUsers |
Authorized users. This constant is deprecated. |
ObsClient.enums.GroupLogDelivery |
LogDelivery |
Log delivery group. This constant is deprecated. |
Constant |
Default Value |
Description |
ObsClient.enums.PermissionRead |
READ |
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
ObsClient.enums.PermissionWrite |
WRITE |
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not applicable to objects. |
ObsClient.enums.PermissionReadAcp |
READ_ACP |
A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
ObsClient.enums.PermissionWriteAcp |
WRITE_ACP |
A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
ObsClient.enums.PermissionFullControl |
FULL_CONTROL |
A grantee with this permission for a bucket has PermissionRead, PermissionWrite, PermissionReadAcp, and PermissionWriteAcp permissions for the bucket. A grantee with this permission for an object has PermissionRead, PermissionReadAcp, and PermissionWriteAcp permissions for the object. |
Code Examples
This example returns the ACL of object example/objectname.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getObjectAcl() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify the object (example/objectname in this example). Key: 'example/objectname', }; // Obtain the object ACL. const result = await obsClient.getObjectAcl(params); if (result.CommonMsg.Status <= 300) { console.log("Get object(%s)'s acl successful with bucket(%s)!", params.Key, params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); console.log('Owner[ID]: %s', result.InterfaceResult.Owner.ID); console.log('Owner[Name]: %s', result.InterfaceResult.Owner.Name); for (let i = 0; i < result.InterfaceResult.Grants.length; i++) { const grant = result.InterfaceResult.Grants[i]; fmt.Printf("Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s\n", index, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission) }; return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; getObjectAcl(); |
Feedback
Was this page helpful?
Chatbot
