Obtaining the Lifecycle Rules of a Bucket (SDK for Node.js)
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API returns the lifecycle rules of a bucket.
Restrictions
- To obtain the lifecycle rules of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetLifecycleConfiguration in IAM or GetLifecycleConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
Method
ObsClient.getBucketLifecycle(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Responses
Type |
Description |
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 3. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Parameter |
Type |
Description |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
Rules |
Yes Explanation: Lifecycle rule information. For details, see Table 6. |
Parameter |
Type |
Description |
ID |
string |
Explanation: Lifecycle rule ID. |
Prefix |
string |
Explanation: Object name prefix. It identifies the objects the rule applies to. You can leave this parameter blank to apply the rule to all objects in the bucket. Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you set Prefix to ExampleObject.jpg, the rule applies to object ExampleObject.jpg alone. If you set Prefix to logs/, the rule applies to objects logs/day1, logs/day2, and logs/day3. If you leave Prefix blank, the rule applies to all objects in the bucket. |
Status |
string |
Explanation: Whether the rule is enabled. Value range: Enabled Disabled |
Transitions |
Explanation: Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 7. Restrictions: This parameter is only available for the latest object version. |
Expiration |
Explanation: Object expiration time. For details, see Table 8. Restrictions: This parameter is only available for the latest object version. |
NoncurrentVersionTransitions |
Explanation: Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 9. Restrictions:
NoncurrentVersionExpiration |
Explanation: Expiration time of historical object versions. For details, see Table 10. Restrictions:
Parameter |
Type |
Description |
StorageClass |
Explanation: Storage class of the object after transition |
Date |
string |
Explanation: OBS executes the lifecycle rule for objects that were modified before the specified date. |
Days |
number |
Explanation: How many days can pass since the last update before the lifecycle rule takes effect |
Parameter |
Type |
Description |
Date |
string |
Explanation: OBS executes the lifecycle rule (deletion) for objects that were modified before the specified date. |
Days |
number |
Explanation: How many days can pass since the last update before the lifecycle rule (deletion) takes effect |
Parameter |
Type |
Description |
StorageClass |
Explanation: Storage class of historical object versions after transition |
NoncurrentDays |
number |
Explanation: Number of days an object is historical before the specified rule takes effect |
Parameter |
Type |
Description |
NoncurrentDays |
number |
Parameter |
Type |
Description |
DaysAfterInitiation |
number |
Explanation: Number of days since the initiation of an incomplete multipart upload that OBS will wait before deleting the non-assembled parts (fragments) of the upload |
Constant |
Default Value |
Description |
ObsClient.enums.StorageClassStandard |
STANDARD |
Standard storage class. Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
ObsClient.enums.StorageClassWarm |
WARM |
Infrequent Access storage class. Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed. |
ObsClient.enums.StorageClassCold |
COLD |
Archive storage class. Used for storing rarely accessed (once a year) data. |
Code Examples
You can call ObsClient.getBucketLifecycle to view lifecycle rules of a bucket. The following code shows how to obtain the lifecycle rule of bucket examplebucket:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getBucketLifecycle() { try { const params = { // Specify the bucket name. Bucket: "examplebucket" }; // Obtain the lifecycle rules of the bucket. const result = await obsClient.getBucketLifecycle(params); if (result.CommonMsg.Status <= 300) { console.log("Get bucket(%s)'s lifecycle configuration successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); for (let i = 0; i < result.InterfaceResult.Rules.length; i++) { const rule = result.InterfaceResult.Rules[i]; console.log("ID:%s, Prefix:%s, Status:%s, Expiration[Date]:%s, Expiration[Days]:%d, NoncurrentVersionExpiration[NoncurrentDays]:%s", rule.ID, rule.Prefix, rule.Status, rule.Expiration.Date, rule.Expiration.Days, rule.NoncurrentVersionExpiration.NoncurrentDays ); }; return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; getBucketLifecycle(); |
Feedback
Was this page helpful?
Chatbot
