Updated on 2025-05-09 GMT+08:00
Creating a Bucket (SDK for Python)
Function
This API creates an OBS bucket. Buckets are containers for storing objects (files uploaded to OBS) in OBS.
When creating a bucket, you can also configure parameters such as the storage class, region, and access control list (ACL) as needed.
Restrictions
  • To create a bucket, you must have the obs:bucket:CreateBucket permission. IAM is recommended for granting permissions. For details, see IAM Custom Policies.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
    When creating a bucket, if you use the endpoint obs.myhuaweicloud.com for client initialization, you do not have to specify a region (indicated by location) where the bucket will be created, because OBS automatically creates the bucket in the CN North-Beijing1 (cn-north-1) region. However, if the endpoint you use is not obs.myhuaweicloud.com, you must specify a region that matches the used endpoint, or status code 400 is returned.
    For example, if the endpoint used for initialization is obs.ap-southeast-1.myhuaweicloud.com, you must set Location to ap-southeast-1 when creating a bucket.
  • A maximum of 100 buckets (regardless of regions) can be created for an account. There is no limit on the number and size of objects in a bucket.
  • The created bucket name must be unique in OBS. If you repeatedly create buckets with the same name in the same region, an HTTP status code 200 will be returned. In other cases, creating a bucket with an existing bucket name will have an HTTP status code 409 returned, indicating that such a bucket already exists.
  • The name of a deleted bucket can be reused for another bucket or a parallel file system at least 30 minutes after the deletion.
Method
ObsClient.createBucket(bucketName, header, location, extensionHeaders)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
Default value:
None
header
CreateBucketHeader
No
Explanation:
Headers in the request used for configuring the storage class, redundancy policy, and other basic information about the bucket
Value range:
See Table 2.
Default value:
None
location
str
Yes if the region where the OBS service resides is not the default region
Explanation:
Region where a bucket will be created.
Restrictions:
If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required.
Value range:
To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator.
Default value:
If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default.
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Table 2 CreateBucketHeader
Parameter
Type
Mandatory (Yes/No)
Description
aclControl
str
No
Explanation:
ACL that can be pre-defined during bucket creation
Value range:
For details, see HeadPermission.
Default value:
PRIVATE
storageClass
str
No
Explanation:
Bucket storage class that can be pre-defined during bucket creation
Value range:
See Table 4.
Default value:
STANDARD
extensionGrants
list of ExtensionGrant
No
Explanation:
Extended permission list that can be specified during bucket creation
Value range:
See Table 5.
Default value:
None
availableZone
str
No
Explanation:
Data redundancy type that can be specified during bucket creation
Restrictions:
Multi-AZ redundancy is not available for Archive storage. If the region where the bucket is located does not support multi-AZ storage, single-AZ storage is used by default.
Value range:
To configure multi-AZ storage for the bucket, set this parameter to 3az. To configure single-AZ storage (default value assigned by OBS) for the bucket, you do not need to specify this parameter.
Default value:
If this parameter is left blank, single AZ is used by default.
epid
str
No
Explanation:
Enterprise project ID that can be specified during bucket creation. If you have enabled Enterprise Project Management Service (EPS), you can obtain the project ID from the EPS console.
Restrictions:
The value of Epid is a Universally Unique Identifier (UUID). Epid is not required if you have not enabled EPS yet.
Example: 9892d768-2d13-450f-aac7-ed0e44c2585f
Value range:
See How Do I Obtain an Enterprise Project ID?
Default value:
None
isPFS
bool
No
Explanation:
Whether a parallel file system is created
Value range:
  • True: A parallel file system is created.
  • False: A bucket is created.
Default value:
False
Table 3 HeadPermission
Constant
Default Value
Description
HeadPermission.PRIVATE
private
Private read/write
A bucket or object can only be accessed by its owner.
HeadPermission.PUBLIC_READ
public-read
Public read and private write
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket.
If it is granted on an object, anyone can read the content and metadata of the object.
HeadPermission.PUBLIC_READ_WRITE
public-read-write
Public read/write
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks.
HeadPermission.PUBLIC_READ_DELIVERED
public-read-delivered
Public read on a bucket as well as objects in the bucket
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket.
NOTE:
PUBLIC_READ_DELIVERED cannot be applied to objects.
HeadPermission.PUBLIC_READ_WRITE_DELIVERED
public-read-write-delivered
Public read/write on a bucket as well as objects in the bucket
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
NOTE:
PUBLIC_READ_WRITE_DELIVERED cannot be applied to objects.
HeadPermission.BUCKET_OWNER_FULL_CONTROL
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object.
Table 4 StorageClass
Parameter
Type
Description
STANDARD
Standard storage class
Explanation:
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
WARM
Infrequent Access storage class
Explanation:
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
COLD
Archive storage class
Explanation:
Used for storing rarely accessed (once a year) data.
Table 5 ExtensionGrant
Parameter
Type
Mandatory (Yes/No)
Description
granteeId
str
No
Explanation:
Account (domain) ID of the grantee
Value range:
To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python)
Default value:
None
permission
str
No
Explanation:
Custom permissions for the bucket
Value range:
You can select one or more permissions from Table 6.
Default value:
None
Table 6 Permission
Constant
Description
READ
Read permission
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
WRITE
Write permission
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
Such permission for an object is not applicable.
READ_ACP
Permission to read ACL configurations
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for the bucket or object permanently.
WRITE_ACP
Permission to modify ACL configurations
A grantee with this permission can update the ACL of a bucket or object.
A grantee with this permission can modify the ACL, thus obtaining full access permissions.
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object.
Responses
Table 7 List of returned results
Type
Description
GetResult
Explanation:
SDK common results
Table 8 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
Code Examples
This example creates a bucket named examplebucket and specifies its location, ACL, storage class, and redundancy type.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
from obs import CreateBucketHeader, HeadPermission
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    # Add additional headers to specify a private bucket in the Standard storage class that supports multi-AZ storage.
    header = CreateBucketHeader(aclControl=HeadPermission.PRIVATE, storageClass="STANDARD", availableZone="3az")
    # Specify the region where the bucket is to be created. The region must be the same as that in the endpoint passed. ap-southeast-1 is used as an example.
    location = "ap-southeast-1"
    bucketName = "examplebucket"
    # Create a bucket.
    resp = obsClient.createBucket(bucketName, header, location)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Create Bucket Succeeded')
        print('requestId:', resp.requestId)
    else:
        print('Create Bucket Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
