Uploading an Object - Append (SDK for Python)
Function
This API uploads a file or folder to an existing OBS bucket. These files can be texts, images, videos, or any other type of files.
The AppendObject operation adds data to the end of an object in a specified bucket. If there is no object with the same key values in the bucket, a new object is created.
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- Uploaded objects are stored in buckets. To upload an object to a bucket, you must have the write permission for the bucket. The name of each object in a bucket must be unique.
- The latest modification time of the object is updated each time an upload is appended.
- If you use SSE-C encryption, the encryption header you configure, such as x-obs-server-side-encryption, must be carried in each append upload.
- If you use SSE-KMS encryption, the encryption header you configure, such as x-obs-server-side-encryption, only needs to be carried when the object is uploaded for the first time and no object with the same name exists in the bucket.
- The size of each append upload cannot exceed 5 GB.
- The maximum number of append writes for each appendable object is 10,000.
- If the storage class is COLD (Archive), this API cannot be called.
- If cross-region replication is configured for a bucket, this API cannot be called.
- Objects cannot be appended to parallel file systems.
Method
ObsClient.appendObject(bucketName, objectKey, content, metadata, headers, progressCallback, autoClose, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
objectKey |
str |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
content |
Yes |
Explanation: Content to be appended Value range: See Table 2. Default value: None |
metadata |
dict |
No |
Explanation: Custom metadata to be appended. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
headers |
No |
Explanation: Headers in the request used for configuring the storage class, redundancy policy, and other basic information about the object Restrictions: This parameter is valid only for the first append upload. Value range: See Table 3. Default value: None |
progressCallback |
callable |
No |
Explanation: Callback function for obtaining the upload progress Default value: None
NOTE:
This function contains the following parameters in sequence: number of uploaded bytes, total number of bytes, and used time (in seconds). For details about the sample code, see Obtaining the Upload Progress (SDK for Python). |
autoClose |
bool |
No |
Explanation: Whether or not to automatically close data streams after the upload is complete Value range: True: The data stream is automatically closed. False: The data stream is not automatically closed. Default value: True |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Header (SDK for Python). Default value: None |
Parameter |
Type |
Description |
content |
str or readable object |
No |
NOTE:
If content is a readable object that contains the read attribute, data can be read from content. Otherwise, the object content is a character string. Default value: None |
position |
int or str |
Yes |
Explanation: Position where the object data is appended Restrictions: For an object to be appended, the value of position must be set to 0 when the object is uploaded for the first time. For the second append upload, the value of position should be set to the value of nextPosition returned in the response when the first upload is successful. Value range: An integer greater than or equal to 0, in bytes Default value: 0 |
offset |
int or str |
No |
Explanation: Offset, in bytes. This parameter is required if the content for an append upload is a local file. Value range: An integer greater than or equal to 0, in bytes Default value: 0 |
isFile |
bool |
No |
Explanation: Whether content indicates the file path. Value range: True: content indicates the file path. False: content does not indicate the file path. Default value: False |
Parameter |
Type |
Description |
md5 |
str |
No |
Explanation: Base64-encoded MD5 value of the content to be appended. It is used for the OBS server to verify data integrity. Value range: Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864 Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
acl |
str |
No |
Explanation: Pre-defined ACL, which can be specified in the append upload request. For details about the ACL, see ACLs. Restrictions: This parameter can only be configured in the first request for append upload. The configurations specified in the first request will be used in subsequent requests by default. Value range: For details about the available options, see HeadPermission. Default value: None |
location |
str |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: location:/anotherPage.html The request is redirected to an external URL http://www.example.com/: location:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata location. Restrictions:
contentType |
str |
No |
Explanation: MIME type of the object specified in the first append upload MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Python SDK) Restrictions: This parameter can only be configured in the first request for append upload. The configurations specified in the first request will be used in subsequent requests by default. Default value: If you do not specify contentType when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to contentType. |
contentLength |
int |
No |
Explanation: Length of the content to be appended Restrictions:
Default value: If this parameter is not specified, OBS SDK for Python automatically calculates the size of the object. |
sseHeader |
or |
No |
Explanation: Server-side encryption header Restrictions: This parameter can only be configured in the first request for append upload. The configurations specified in the first request will be used in subsequent requests by default. Default value: None |
storageClass |
str |
No |
Explanation: Storage class of the object that can be specified in the append upload request Restrictions: This parameter can only be configured in the first request for append upload. The configurations specified in the first request will be used in subsequent requests by default. Value range:
successActionRedirect |
str |
No |
Explanation: Address (URL) to which a successfully answered request is redirected
extensionGrants |
list of ExtensionGrant |
No |
Explanation: List of extension permissions that can be specified in the append upload request Restrictions: This parameter can only be configured in the first request for append upload. The configurations specified in the first request will be used in subsequent requests by default. Value range: See Table 8. Default value: The value specified in the first append upload request |
expires |
int |
No |
Explanation: Lifecycle (starting from the last modification time of the object) that can be specified in the append upload request. Once the object expires, it is automatically deleted. Restrictions:
Value range: An integer greater than or equal to 0, in days Default value: None |
Constant |
Default Value |
Description |
HeadPermission.PRIVATE |
private |
Private read/write A bucket or object can only be accessed by its owner. |
HeadPermission.PUBLIC_READ |
public-read |
Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket. If it is granted on an object, anyone can read the content and metadata of the object. |
HeadPermission.PUBLIC_READ_WRITE |
public-read-write |
Public read/write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If it is granted on an object, anyone can read the content and metadata of the object. |
HeadPermission.PUBLIC_READ_DELIVERED |
public-read-delivered |
Public read on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket.
NOTE:
PUBLIC_READ_DELIVERED cannot be applied to objects. |
HeadPermission.PUBLIC_READ_WRITE_DELIVERED |
public-read-write-delivered |
Public read/write on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
NOTE:
PUBLIC_READ_WRITE_DELIVERED cannot be applied to objects. |
HeadPermission.BUCKET_OWNER_FULL_CONTROL |
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. |
Parameter |
Type |
Description |
STANDARD |
Standard storage class |
Explanation: Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
WARM |
Infrequent Access storage class |
Explanation: Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
COLD |
Archive storage class |
Explanation: Used for storing rarely accessed (once a year) data. |
Parameter |
Type |
Description |
encryption |
str |
Yes |
Explanation: SSE-C used for encrypting objects Value range: AES256 Default value: None |
key |
str |
Yes |
Explanation: Key used in SSE-C encryption. It corresponds to the encryption method. For example, if encryption is set to AES256, the key is calculated using the AES-256 algorithm. Value range: The value must contain 32 characters. Default value: None |
Parameter |
Type |
Description |
encryption |
str |
Yes |
Explanation: SSE-KMS used for encrypting objects Value range: kms Default value: None |
key |
str |
No |
Explanation: Master key used in SSE-KMS Value range: The following two formats are supported:
In the preceding formats:
Default value:
Parameter |
Type |
Description |
granteeId |
str |
No |
Explanation: Account (domain) ID of the grantee Value range: To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python) Default value: None |
permission |
str |
No |
Explanation: Granted permissions Default value: None |
Constant |
Description |
READ |
Read permission A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
WRITE |
Write permission A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. Such permission for an object is not applicable. |
READ_ACP |
Permission to read ACL configurations A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for the bucket or object permanently. |
WRITE_ACP |
Permission to modify ACL configurations A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for the bucket or object permanently. A grantee with this permission can modify the ACL, thus obtaining full access permissions. |
FULL_CONTROL |
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
GetResult.body Type |
Description |
Explanation: Response to the append upload request. For details, see Table 13. |
Parameter |
Type |
Description |
storageClass |
str |
Explanation: Object storage class. Value range:
etag |
str |
Explanation: ETag of an object, which is a base64-encoded 128-bit MD5 digest. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, the object content is changed. The ETag reflects changes only to the contents of the object, not its metadata. An uploaded object or copied object has a unique ETag. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
nextPosition |
int |
Explanation: Start position for next appending Value range: An integer greater than or equal to 0, in bytes Default value: None |
sseKms |
str |
Explanation: SSE-KMS algorithm Value range: kms Default value: None |
sseKmsKey |
str |
Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
Default value:
sseC |
str |
Explanation: SSE-C algorithm Value range: AES256 Default value: None |
sseCKeyMd5 |
str |
Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Default value: None |
objectUrl |
str |
Explanation: Full path to the object Default value: None |
Code Examples
This example appends content to an object.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 |
from obs import ObsClient from obs import AppendObjectContent import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Specify the message body of the request for an append upload. content = AppendObjectContent() # Specify the content to be appended. content.content = 'Hello OBS' # Specify the starting position (byte 0 in this example) the content is appended to. content.position = 0 # If you upload an object for the first time using the append upload, an error will be reported (status code 409) if an ordinary object with the same name already exists. bucketName = "examplebucket" # Specify the name of the object to append content to. objectKey = "objectname" # Append content to the object. resp = obsClient.appendObject(bucketName, objectKey, content) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Append Object Succeeded') print('requestId:', resp.requestId) print('nextPosition:', resp.body.nextPosition) else: print('Append Object Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Append Object Failed') print(traceback.format_exc()) |
- Objects uploaded using ObsClient.putObject, referred to as common objects, can overwrite objects uploaded using ObsClient.appendObject, referred to as appendable objects. Data cannot be appended to an appendable object anymore once the object has been overwritten by a common object.
- When you upload an object for the first time in appendable mode, an exception will be reported (HTTP status code 409) if a common object with the same name exists.
- The ETag returned for the append upload is the ETag for the appended content, rather than that of the whole object.
- Data appended each time can be up to 5 GB, and a maximum of 10,000 uploads can be appended for an object.
- After an append upload is successful, you can obtain the location for the next append upload by using body.nextPosition in the returned results or call ObsClient.getObjectMetadata.
Feedback
Was this page helpful?
Chatbot
