Uploading an Object - Browser-Based (SDK for Python)
Function
This API uploads an object up to 5 GB to a specified bucket in HTML form. You can call ObsClient.createPostSignature to generate parameters for requesting a browser-based upload. For details about the sample code for a browser-based upload, see post_object_sample. You can also perform a browser-based upload with the following steps:
- Call ObsClient.createPostSignature to generate request parameters for authentication.
- Prepare an HTML form.
- Enter the request parameters in the page.
- Select a local file and upload it in browser-based mode.
There are two request parameters generated for authentication:
- policy, which corresponds to the policy parameter in the form.
- signature, which corresponds to the signature parameter in the form.
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- Values of policy and signature in the HTML form are obtained from the returned results of ObsClient.createPostSignature. You can directly download the HTML form example PostDemo.
Method
ObsClient.createPostSignature(bucketName, objectKey, expires, formParams)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
No |
Explanation: Bucket name Restrictions:
Default value: None |
objectKey |
str |
No |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
expires |
int |
No |
Explanation: Expiration time of authentication for a browser-based upload Value range: A positive integer, in seconds Default value: 300 |
formParams |
dict |
No |
Explanation: Parameters of browser-based uploads, not including key, policy, and signature. Value range: (When you use the following parameters, you must add the x-obs prefix to them. Taking acl as an example, it should be configured as formParams['x-obs-acl']='public-read'. To obtain the values of these parameters, see the response header descriptions in APIs.)
Responses
Parameter |
Type |
Description |
originPolicy |
str |
Explanation: Value of Policy that is not encoded by Base64. This parameter can only be used for verification. For example: {"expiration":"2023-09-12T12:52:59Z","conditions":[{"content-type":"text/plain"},{"bucket":"examplebucket"},{"key":"example/objectname"},]}" Default value: None |
policy |
str |
Explanation: Value of Policy that is encoded by Base64. For example: eyJleHBpcmF0aW9uIjoiMjAyMy0wOS0xMlQxMjo1Mjo1OVoiLCJjb25kaXRpb25zIjpbeyJjb250ZW50LXR5cGUiOiJ0ZXh0L3BsYWluIn0seyJidWNrZXQiOiJleGFtcGxlYnVja2V0In0seyJrZXkiOiJleGFtcGxlL29iamVjdG5hbWUifSxdfQ== Default value: None |
signature |
str |
Explanation: signature in the form For example: g0jQr4v9VWd1Q2FOFDG6LGfV9Cw= Default value: None |
Code Examples
This example generates authentication parameters policy and signature for a browser-based upload.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 |
from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" objectKey = "objectname" # Configure the validity period (in seconds) for a browser-based upload request. 3600 is used as an example. expires = 3600 # Specify parameters for a browser-based upload except key, policy, and signature. In this example, x-obs-acl is set to private and content-type is set to text/plain. formParams = {'x-obs-acl': 'private', 'content-type': 'text/plain'} # Create parameters for a browser-based upload. resp = obsClient.createPostSignature(bucketName, objectKey, expires, formParams) print('originPolicy:', resp.originPolicy) print('policy:', resp.policy) print('signature:', resp.signature) except: print(traceback.format_exc()) |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 |
<html> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> </head> <body> <form action="http://bucketname.your-endpoint/" method="post" enctype="multipart/form-data"> <p> Object key </p> <!-- Object name --> <input type="text" name="key" value="objectname" /> <p> ACL </p> <!-- Object ACL --> <input type="text" name="x-obs-acl" value="private" /> <p> Content-Type </p> <!-- Object MIME type --> <input type="text" name="content-type" value="text/plain" /> <p> <!-- Base64-encoded policy --> <input type="hidden" name="policy" value="*** Provide your policy ***" /> <!-- AK --> <input type="hidden" name="AccessKeyId" value="*** Provide your access key ***"/> <!-- Signature string information --> <input type="hidden" name="signature" value="*** Provide your signature ***"/> <input name="file" type="file" /> <input name="submit" value="Upload" type="submit" /> </p> </form> </body> </html> |
- You can directly download the HTML form example PostDemo.
Feedback
Was this page helpful?
Chatbot
