dateadd
This function is used to change a date based on datepart and delta.
To obtain the date with a specified change range based on the current date, use this function together with the current_date or getdate function.
Syntax
dateadd(string date, bigint delta, string datepart)
Parameters
Parameter |
Mandatory |
Type |
Description |
date |
Yes |
DATE or STRING |
Start date The following formats are supported:
delta |
Yes |
BIGINT |
Amplitude, based on which the date is modified |
datepart |
Yes |
STRING |
Unit, based on which the date is modified This parameter supports the following extended date formats: year, month or mon, day, and hour.
Return Values
The return value is of the STRING type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
- If the value of delta or datepart is NULL, NULL is returned.
Example Code
The value 2023-08-15 17:00:00 is returned after one day is added.
select dateadd( '2023-08-14 17:00:00', 1, 'dd');
The value 2025-04-14 17:00:00 is returned after 20 months are added.
select dateadd('2023-08-14 17:00:00', 20, 'mm');
The value 2023-09-14 17:00:00 is returned.
select dateadd('2023-08-14 17:00:00', 1, 'mm');
The value 2023-09-14 is returned.
select dateadd('2023-08-14', 1, 'mm');
If the current time is 2023-08-14 17:00:00, 2023-08-13 17:00:00 is returned.
select dateadd(getdate(),-1,'dd');
The value NULL is returned.
select dateadd(date '2023-08-14', 1, null);
Feedback
Was this page helpful?
Chatbot
