Help Center/ Cloud Service Engine/ User Guide/ Nacos Engines/ Viewing Monitoring of a Nacos Engine
Updated on 2025-09-19 GMT+08:00
When using the Nacos engine, you can view common metrics related to the Nacos engine in the configuration center and registry center on the running monitoring page provided by the CSE console. This section describes how to view monitoring metrics of Nacos engines.
To view the running Nacos monitoring data, ensure that you have the AOM FullAccess permission.
  1. Log in to CSE.
  2. In the left navigation pane, choose Registry/Configuration Center.
  3. Click the target Nacos engine.
  4. In the left navigation pane, choose Monitoring. You can view Nacos monitoring metrics.
    • On the Dashboard tab page, you can view Microservice Instances and Configurations. In addition, Microservice Instance Use and Configuration Use are displayed in graphics.
      • Microservice Instance Use: Ratio of the number of connected microservice instances to the recommended max. number of microservice instances. Increase instances for a high ratio.
      • Configuration Use: Ratio of created configurations to the max. configurations allowed.
    • On the Configuration Center Monitoring tab page, you can select a time from the drop-down list in the upper right corner to view the monitoring data of the configuration center in a specified period, including Configurations, Long Connections, Write Request Frequency, Read Request Frequency, Average Response Time for Write Request, Average Response Time for Read Request, and Configuration Push Time Required. The value can be Last 30 minutes, Last 1 hour, Last 6 hours, Last 1 day, or Last week. By default, the monitoring data of the last 30 minutes is displayed.
    • On the Registry Center Monitoring tab page, you can select a time from the drop-down list in the upper right corner to view the monitoring data of the registry center in a specified period, including Microservices, Microservice Instances, Write Request Frequency, Read Request Frequency, Average Response Time for Write Request, Average Response Time for Read Request, and Service Push Time Required. The value can be Last 30 minutes, Last 1 hour, Last 6 hours, Last 1 day, or Last week. By default, the monitoring data of the last 30 minutes is displayed.
