Help Center/
Cloud Service Engine/
User Guide/
ServiceComb Engines/
Configuration Management (Applicable to ServiceComb Engine 1.x)/
Managing Configurations for ServiceComb Engine 1.x
Updated on 2025-09-19 GMT+08:00
Editing a Configuration
- Log in to CSE.
- Choose Exclusive ServiceComb Engines.
- Click the target engine.
- Choose Configuration Management.
- For engines with security authentication disabled, go to 6.
- For engines with security authentication enabled, if the login user is the user imported in Importing an IAM Account, go to 6. For other users, go to 5.
- In the displayed Security Authentication dialog box, enter the account name and password, and click OK.
- If you connect to the ServiceComb engine for the first time, enter the account name root and the password entered when Creating a ServiceComb Engine.
- For details about how to create an account, see Adding an Account.
- Click Edit in the Operation column of the target configuration item and edit the values of the configuration item.
- Click OK.
Importing Configurations
- Log in to CSE.
- Click Import.
- Select a microservice environment, click Import, and select the target file. A maximum of 150 configuration items can be imported at a time.
- Click Close.
Exporting Configurations
- Log in to CSE.
- Click Export All.
Deleting a Configuration
- Log in to CSE.
- Select the target configuration item and click Delete. You can also click Delete in the Operation column of the target configuration item.
- Click OK.
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
