Help Center/
Data Lake Insight/
SQL Syntax Reference (Kuala Lumpur Region)/
Spark SQL Syntax Reference/
Built-in Functions/
String Functions/
space
Updated on 2025-01-22 GMT+08:00
space
This function is used to return a specified number of spaces.
Syntax
space(bigint <n>)
Parameters
Parameter |
Mandatory |
Type |
Description |
n |
Yes |
BIGINT |
Number of spaces |
Return Values
The return value is of the STRING type.
- If the value of n is empty, an error is reported.
- If the value of n is NULL, NULL is returned.
Example Code
The value 6 is returned.
select length(space(6));
Parent topic: String Functions
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
