Updated on 2025-05-16 GMT+08:00
Managing Bucket ACLs
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources.
For more information, see ACLs.
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
A bucket ACL can be configured in any of the following ways:
  1. Specify a pre-defined ACL when creating a bucket.
  2. Call ObsClient.SetBucketAcl to specify a pre-defined ACL.
  3. Call ObsClient.SetBucketAcl to specify a user-defined ACL.
The following table lists the five permission types supported by OBS.
Permission
Description
Value in OBS .NET SDK
READ
A grantee with this permission for a bucket can obtain the list of objects in the bucket and the metadata of the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
PermissionEnum.Read
WRITE
A grantee with this permission for a bucket can upload, overwrite, and delete any object in the bucket.
Such permission for an object is not applicable.
PermissionEnum.Write
READ_ACP
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission permanently.
PermissionEnum.ReadAcp
WRITE_ACP
A grantee with this permission can update the ACL of a bucket or object.
A grantee with this permission can modify the access control policy and thus the grantee obtains full access permissions.
PermissionEnum.WriteAcp
FULL_CONTROL
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the object.
PermissionEnum.FullControl
There are five access control policies pre-defined in OBS, as described in the following table:
Policy
Description
private
The owner of a bucket or object has the FULL_CONTROL permission for the bucket or object. Other users have no permission to access the bucket or object.
CannedAclEnum.Private
public-read
If this permission is set for a bucket, everyone can obtain the list of objects, multipart uploads, and object versions in the bucket, as well as metadata of the bucket.
If this permission is set for an object, everyone can obtain the content and metadata of the object.
CannedAclEnum.PublicRead
public-read-write
If this permission is set for a bucket, everyone can obtain the object list in the bucket, multipart uploads in the bucket, metadata of the bucket; upload objects; delete objects; initialize multipart uploads; upload parts; combine parts; copy parts; and abort multipart uploads.
CannedAclEnum.PublicReadWrite
public-read-delivered
If this permission is set for a bucket, everyone can obtain the object list, multipart uploads, and bucket metadata in the bucket, and obtain the content and metadata of the objects in the bucket.
This permission cannot be set for objects.
CannedAclEnum.PublicReadDelivered
public-read-write-delivered
If this permission is set for a bucket, everyone can obtain the object list in the bucket, multipart uploads in the bucket, metadata of the bucket; upload objects; delete objects; initialize multipart uploads; upload parts; combine parts; copy parts; abort multipart uploads; and obtain content and metadata of objects in the bucket.
CannedAclEnum.PublicReadWriteDelivered
Specifying a Pre-defined ACL During Bucket Creation
Sample code:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Create a bucket.
try
    CreateBucketRequest request = new CreateBucketRequest
        BucketName = "bucketname",
        // Set the bucket ACL to public read and write.
        CannedAcl = CannedAclEnum.PublicReadWrite,
    CreateBucketResponse response = client.CreateBucket(request);
    Console.WriteLine("StatusCode: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
Setting a Pre-defined ACL for a Bucket
Sample code:
//Set the bucket ACL.
try
    SetBucketAclRequest request = new SetBucketAclRequest
        // Set the bucket ACL to be private.
        CannedAcl = CannedAclEnum.Private
    SetBucketAclResponse response = client.SetBucketAcl(request);
    Console.WriteLine("Set bucket acl response: {0}", response.StatusCode);
Setting a User-defined Bucket ACL
The following code shows how to set a user-defined ACL for a bucket:
try
    //Set the bucket owner.
    Owner owner = new Owner
        Id = "ownerid",//ID of the domain to which the owner belongs
    AccessControlList acl = new AccessControlList();
    acl.Owner = owner ;
    Grant item = new Grant()
        Grantee = new GroupGrantee()
            GroupGranteeType = GroupGranteeEnum.AllUsers
        Permission = PermissionEnum.FullControl
    IList<Grant> grants = new List<Grant>();
    grants.Add(item);
    acl.Grants = grants;
    SetBucketAclRequest request = new SetBucketAclRequest()
        AccessControlList = acl
The owner or grantee ID needed in the ACL indicates the account ID, which can be viewed on the My Credentials page of OBS Console.
Obtaining a Bucket ACL
You can call ObsClient.GetBucketAcl to obtain the bucket ACL. Sample code is as follows:
//Obtain the bucket ACL.
try
    GetBucketAclRequest request = new GetBucketAclRequest
    GetBucketAclResponse response = client.GetBucketAcl(request);
    Console.WriteLine("Get bucket acl response: {0}", response.StatusCode);
    foreach(Grant grant in response.AccessControlList.Grants)
        if(grant.Grantee is CanonicalGrantee)
              Console.WriteLine("Grantee id: {0}", (grant.Grantee as CanonicalGrantee).Id);
        }else if(grant.Grantee is GroupGrantee)
              Console.WriteLine("Grantee type: {0}", (grant.Grantee as GroupGrantee).GroupGranteeType);
              Console.WriteLine("Grant permission: {0}", grant.Permission);
