Updated on 2023-12-25 GMT+08:00
Rewriting Response Headers
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
When downloading an object, you can rewrite some HTTP/HTTPS response headers. The following table lists rewritable response headers.
Parameter
Description
Property in OBS .NET SDK
ContentType
Rewrites Content-Type in HTTP/HTTPS responses.
GetObjectRequest.ResponseHeaderOverrides.ContentType
ContentLanguage
Rewrites Content-Language in HTTP/HTTPS responses.
GetObjectRequest.ResponseHeaderOverrides.ContentLanguage
Expires
Rewrites Expires in HTTP/HTTPS responses.
ObjectRepleaceMetadata.Expires
CacheControl
Rewrites Cache-Control in HTTP/HTTPS responses.
GetObjectRequest.ResponseHeaderOverrides.CacheControl
ContentDisposition
Rewrites Content-Disposition in HTTP/HTTPS responses.
GetObjectRequest.ResponseHeaderOverrides.ContentDisposition
ContentEncoding
Rewrites Content-Encoding in HTTP/HTTPS responses.
GetObjectRequest.ResponseHeaderOverrides.ContentEncoding
Sample code:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Rewrite response headers when downloading an object.
try
    ResponseHeaderOverrides responseHeaderOverrides = new ResponseHeaderOverrides();
    responseHeaderOverrides.ContentType = "image/jpeg";
    GetObjectRequest request = new GetObjectRequest()
        BucketName = "bucketname",
        ObjectKey = "objectname",
        ResponseHeaderOverrides = responseHeaderOverrides,
    GetObjectResponse response = client.GetObject(request);
    Console.WriteLine("Get object response: {0}", response.StatusCode);
    Console.WriteLine("ContentType: {0}", response.ContentType);
    response.Dispose();
catch (ObsException ex)
   Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
   Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
