Disabling Bucket Logging
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
To disable logging for a bucket is to call ObsClient.SetBucketLogging to delete the logging configuration.
This example disables logging for bucket bucketname.
The example code is as follows:
// Initialize configuration parameters. ObsConfig config = new ObsConfig(); config.Endpoint = "https://your-endpoint"; // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine); string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine); // Create an instance of ObsClient. ObsClient client = new ObsClient(accessKey, secretKey, config); try { SetBucketLoggingRequest putrequest = new SetBucketLoggingRequest(); putrequest.BucketName = "bucketname";//Source bucket putrequest.Configuration = new LoggingConfiguration(); SetBucketLoggingResponse putresponse = client.SetBucketLogging(putrequest); Console.WriteLine("Delete bucket logging response: {0}", putresponse.StatusCode); } catch (ObsException ex) { Console.WriteLine("ErrorCode: {0}", ex.ErrorCode); Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage); }
Feedback
Was this page helpful?
Chatbot
