Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Obtaining the Logging Configuration of a Bucket (SDK for Go)
Updated on 2024-12-09 GMT+08:00
Function
This API returns the logging configuration of a bucket.
Restrictions
Method
func (obsClient ObsClient) GetBucketLoggingConfiguration(bucketName string) (output *GetBucketLoggingConfigurationOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 2 List of returned results
Parameter
Type
Description
output
Explanation:
Returned results. For details, see Table 3.
err
error
Explanation:
Error messages returned by the API
Table 3 GetBucketLoggingConfigurationOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Agency
string
Explanation:
Name of the IAM agency created by the owner of the target bucket for OBS.
You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency.
Restrictions:
By default, the IAM agency only requires the PutObject permission to upload logs to the target bucket. If default encryption is enabled for the target bucket, the agency also requires the KMS Administrator permission in the region where the target bucket is located.
Default value:
None
TargetBucket
string
Explanation:
Name of the bucket for storing log files
Restrictions:
  • This bucket must be in the same region as the bucket with logging enabled.
  • A bucket name:
Default value:
None
TargetPrefix
string
Explanation:
Name prefix for log files stored in the log storage bucket
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
TargetGrants
[]Grant
Explanation:
Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 4.
Table 4 Grant
Parameter
Type
Description
Grantee
Grantee
Explanation:
Grantee information. For details, see Table 5.
Permission
PermissionType
Explanation:
Granted permission
Value range:
See Table 8.
Default value:
None
Table 5 Grantee
Parameter
Type
Description
Type
GranteeType
Explanation:
Grantee type
Value range:
See Table 6.
Default value:
None
ID
string
Explanation:
Account (domain) ID of the grantee
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
DisplayName
string
Explanation:
Account name of the grantee
Restrictions:
  • Starts with a letter. Contains 6 to 32 characters.
  • Contains only letters, digits, hyphens (-), or underscores (_).
Default value:
None
URI
GroupUriType
Explanation:
Authorized user group. For details, see Table 7.
Table 6 GranteeType
Constant
Default Value
Description
GranteeGroup
Group
User group
GranteeUser
CanonicalUser
Individual user
Table 7 GroupUriType
Constant
Default Value
Description
GroupAllUsers
AllUsers
All users
Table 8 PermissionType
Constant
Default Value
Description
PermissionRead
READ
Read permission
PermissionWrite
WRITE
Write permission
PermissionReadAcp
READ_ACP
Permission to read ACL configurations
PermissionWriteAcp
WRITE_ACP
Permission to modify ACL configurations
PermissionFullControl
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
Code Examples
This example returns the logging configuration of bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSignature(obs.SignatureObs)/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    // Specify a bucket name.
    bucketname := "examplebucket"
    // Obtain the logging configuration of the bucket.
    output, err := obsClient.GetBucketLoggingConfiguration(bucketname)
    if err == nil {
        fmt.Printf("Get bucket(%s)'s BucketLoggingConfiguration successful!\n", bucketname)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        fmt.Printf("TargetBucket:%s, TargetPrefix:%s\n", output.TargetBucket, output.TargetPrefix)
        for index, grant := range output.TargetGrants {
            fmt.Printf("Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s\n",
                index, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission)
        return
    fmt.Printf("Get bucket(%s)'s BucketLoggingConfiguration fail!\n", bucketname)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
