Obtaining the Custom Domain Name of a Bucket (SDK for Go)
Function
This API obtains the custom domain name of a bucket.
Restrictions
- To obtain the custom domain name for a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketCustomDomainConfiguration in IAM or GetBucketCustomDomainConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) GetBucketCustomDomain(bucketName string) (output *GetBucketCustomDomainOuput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 3. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Domains |
[]Domain |
Explanation: Domain information. For details, see Table 4. |
Parameter |
Type |
Description |
DomainName |
string |
Explanation: User-defined domain name Restrictions: The value must comply with the domain name rules. Default value: The value can be up to 256 bytes. Default value: None |
CreateTime |
string |
Explanation: Time when the custom domain name was created For example: 2019-03-13T10:22:05.912Z |
Code Examples
This example returns the custom domain name of bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken)) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Specify a bucket name. bucketname := "examplebucket" // Obtain the custom domain name of the bucket. output, err := obsClient.GetBucketCustomDomain(bucketname) if err == nil { fmt.Printf("Get bucket(%s)'s customdomain successful!\n", bucketname) fmt.Printf("RequestId:%s\n", output.RequestId) return } fmt.Printf("Get bucket(%s)'s customdomain fail!\n", bucketname) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Helpful Links
Feedback
Was this page helpful?
Chatbot
