Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Initialization (SDK for Node.js)/ Creating an Instance of ObsClient (SDK for Node.js)
Updated on 2024-11-13 GMT+08:00
ObsClient functions as the Node.js client for accessing OBS. It offers callers a series of APIs for interaction with OBS and is used for managing and operating resources, such as buckets and objects, stored in OBS. To use OBS Node.js SDK to send a request to OBS, you need to initialize an instance of ObsClient and modify parameters related to initial configurations of the instance based on actual needs.
By Using the Constructor
  • Sample code for creating an ObsClient instance using permanent access keys (AKs/SKs):
    // Import the OBS library.
    // Use npm to install the client.
    const ObsClient = require("esdk-obs-nodejs");
    // Use the source code to install the client.
    // var ObsClient = require('./lib/obs');
    // Create an instance of ObsClient.
    const obsClient = new ObsClient({
      // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
      // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
      access_key_id: process.env.ACCESS_KEY_ID,
      secret_access_key: process.env.SECRET_ACCESS_KEY,
      // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
      server: "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Use the instance to access OBS.
    // Close the ObsClient instance.
    // obsClient.close();
  • Sample code for creating an ObsClient instance using temporary security credentials (AKs/SKs and security tokens):
      // If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
      security_token: process.env.SECURITY_TOKEN,
By Using the Factory Method
    var ObsClient = require('esdk-obs-nodejs');
    // Initialize an ObsClient instance by using the factory method.
    var obsClient = new ObsClient();
    obsClient.factory({
    obsClient.factory({
  • The project can contain one or more ObsClient instances.
