Updated on 2025-04-02 GMT+08:00
Overview
Table 1 lists the aggregate functions supported by DLI.
Table 1 Aggregate functions
Function
Syntax
Value Type
Description
avg
avg(col), avg(DISTINCT col)
DOUBLE
Returns the average value.
corr
corr(col1, col2)
DOUBLE
Returns the coefficient of correlation of a pair of numeric columns.
count
count([distinct|all] <colname>)
BIGINT
Returns the number of records.
covar_pop
covar_pop(col1, col2)
DOUBLE
Returns the covariance of a pair of numeric columns.
covar_samp
covar_samp(col1, col2)
DOUBLE
Returns the sample covariance of a pair of numeric columns.
max
max(col)
DOUBLE
Returns the maximum value.
min
min(col)
DOUBLE
Returns the minimum value.
percentile
percentile(BIGINT col, p)
DOUBLE
Returns the percentage value point of the value area. The value of p must be between 0 and 1. Otherwise, NULL is returned. The value cannot be a float.
percentile_approx
percentile_approx(DOUBLE col, p [, B])
DOUBLE
Returns the approximate pth percentile of a numerical column within the group, including floating-point numbers. The value of p should be between 0 and 1. The parameter B controls the accuracy of the approximation, with a higher value of B resulting in a higher level of approximation. The default value is 10000. If the number of non-repeating values in the column is less than B, an exact percentile is returned.
stddev_pop
stddev_pop(col)
DOUBLE
Returns the deviation of a specified column.
stddev_samp
stddev_samp(col)
DOUBLE
Returns the sample deviation of a specified column.
sum
sum(col), sum(DISTINCT col)
DOUBLE
Returns the sum of the values in a column.
variance/var_pop
variance(col), var_pop(col)
DOUBLE
Returns the variance of a column.
var_samp
var_samp(col)
DOUBLE
Returns the sample variance of a specified column.
