covar_samp
This function is used to return the sample covariance between two columns of numerical values.
Syntax
covar_samp(col1, col2)
Parameters
Parameter |
Mandatory |
Description |
col1 |
Yes |
Columns with a data type of numeric. If the values are of any other type, NULL is returned. |
col2 |
Yes |
Return Values
The return value is of the DOUBLE type.
Example Code
- Calculates the sample covariance between the inventory (items) and the price of all offerings. An example command is as follows:
select covar_samp(items,price) from warehouse;
The command output is as follows:
_c0 1.242355
- When used with group by, it groups all offerings by warehouse (warehouseId) and returns the sample covariance between the inventory (items) and the price of offerings within each group. An example command is as follows:
select warehouseId, covar_samp(items,price) from warehourse group by warehouseId;
warehouseId _c1 city1 1.03124 city2 1.03344 city3 1.33425
Feedback
Was this page helpful?
Chatbot
