Updated on 2025-04-02 GMT+08:00
tan
This function is used to return the tangent value of a, with input in radians.
Syntax
tan(DOUBLE a)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value 0.9999999999999999 is returned.
select tan(pi()/4);
The value NULL is returned.
select tan(null);
