Managing Nacos Engine Tags
Tags facilitate Nacos engine identification and management.
If your organization has configured tag policies for Nacos engines, add tags to engines based on the policies. If a tag does not comply with the tag policies, engine creation may fail. Contact your administrator to learn more about tag policies.
You can add tags to a Nacos engine when creating the engine or add tags on the details page of the created engine. Up to 20 tags can be added to an engine. Tags can be modified and deleted.
A tag consists of a tag key and a tag value. Table 1 lists the tag key and value requirements.
Tag |
Rule |
Key |
Value |
Managing Tags
Adding or modifying tags will affect Nacos engine services for about 10 seconds. Add or modify tags during off-peak hours.
- Log in to CSE.
- In the left navigation pane, choose Registry/Configuration Center.
- Click the target engine. The details page is displayed.
- In the More Settings area, perform the following operations in the Tags field as required:
- Add a tag
- Click Tag Management. The Edit Tag dialog box is displayed.
- Click
Add Tag and enter a tag key and value in the text boxes.
- Click OK.
- Modify a tag
- You can modify the tag key and value in the original text boxes.
- Click OK.
- Delete a tag
Click
in the row that contains the tag to be deleted. In the dialog box that is displayed, click OK to delete the tag.
- Add a tag
Feedback
Was this page helpful?
Chatbot
