Updated on 2025-01-22 GMT+08:00
min
This function is used to return the minimum value.
Syntax
min(col)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
col
Yes
Any type except BOOLEAN
The value can be of any type except BOOLEAN.
Return Values
The return value is of the DOUBLE type.
The return type is the same as the type of col. The return rules are as follows:
  • If the value of col is NULL, the row is not involved in calculation.
  • If the value of col is of the BOOLEAN type, it cannot be used for calculation.
Example Code
  • Calculates the minimum inventory (items) of all offerings. An example command is as follows:
    select min(items) from warehouse;
    The command output is as follows:
    _c0
    600
  • When used with group by, it returns the minimum inventory of each warehouse. An example command is as follows:
    select warehourseId, min(items) from warehouse group by warehourseId;
    warehouseId _c1
    city1      15
    city2      10
    city3      19
