Updated on 2024-06-21 GMT+08:00
Rewriting Response Headers
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
When downloading an object, you can rewrite some HTTP/HTTPS response headers. The following table lists rewritable response headers.
Parameter
Description
Method in OBS Android SDK
contentType
Rewrites Content-Type in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentType
contentLanguage
Rewrites Content-Language in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentLanguage
expires
Rewrites Expires in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setExpires
cacheControl
Rewrites Cache-Control in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setCacheControl
contentDisposition
Rewrites Content-Disposition in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentDisposition
contentEncoding
Rewrites Content-Encoding in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentEncoding
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
GetObjectRequest request = new GetObjectRequest("bucketname", "objectname");
ObjectRepleaceMetadata replaceMetadata = new ObjectRepleaceMetadata();
replaceMetadata.setContentType("image/jpeg");
request.setReplaceMetadata(replaceMetadata);
ObsObject obsObject = obsClient.getObject(request);
Log.i("GetObject", object.getMetadata().getContentType());
obsObject.getObjectContent().close();
