Updated on 2024-04-26 GMT+08:00
Setting or Obtaining a Bucket Quota
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Setting a Bucket Quota
You can call ObsClient.setBucketQuota to set the bucket quota. Sample code is as follows:
// Create an instance of ObsClient.
var obsClient = new ObsClient({
    // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
    // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    access_key_id: process.env.AccessKeyID,
    secret_access_key: process.env.SecretAccessKey,
    // Replace the example endpoint with the actual one in your case.
    server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
//Set the bucket quota to 100 MB.
obsClient.setBucketQuota({
       Bucket: 'bucketname',
       StorageQuota: 1024 * 1024 * 100
}, function (err, result) {
       if(err){
              console.error('Error-->' + err);
       }else{
              console.log('Status-->' + result.CommonMsg.Status);
  • Use the StorageQuota parameter to specify the bucket quota.
  • A bucket quota must be a non-negative integer expressed in bytes. The maximum value is 263 - 1.
You can call ObsClient.getBucketQuota to obtain the bucket quota. Sample code is as follows:
obsClient.getBucketQuota({
       Bucket : 'bucketname'
       if(err){
       }else{
              if(result.CommonMsg.Status < 300 && result.InterfaceResult){
                     console.log('StorageQuota-->' + result.InterfaceResult.StorageQuota);
