Setting or Obtaining an Object Version ACL
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Setting an ACL for an Object Version
You can call ObsClient.setObjectAcl and specify the VersionId parameter to configure an ACL for an object version. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.setObjectAcl({ Bucket : 'bucketname', Key : 'objectname', VersionId : 'versionid', // Set the object version ACL to public read by specifying a pre-defined ACL. ACL : obsClient.enums.AclPublicRead }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } }); obsClient.setObjectAcl({ Bucket : 'bucketname', Key : 'objectname', VersionId : 'versionid', // Set the object owner. Owner:{'ID':'ownerid'}, Grants:[ // Grant the READ and WRITE_ACP permission to all users. { Grantee:{Type : 'Group', URI : obsClient.enums.GroupAllUsers}, Permission : obsClient.enums.PermissionRead}, { Grantee:{Type : 'Group', URI : obsClient.enums.GroupAllUsers}, Permission : obsClient.enums.PermissionWriteAcp} ] }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
- Use the Owner parameter to specify the object owner and the Grants parameter to specify information about the authorized users.
- The owner or grantee ID required in the ACL indicates an account ID, which can be viewed on the My Credentials page of OBS Console.
- OBS buckets support the following grantee group:
- All users: ObsClient.enums.GroupAllUsers
Obtaining the ACL of an Object Version
You can call ObsClient.getObjectAcl and specify the VersionId parameter to obtain the ACL of an object version. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.getObjectAcl({ Bucket : 'bucketname', Key : 'objectname', VersionId : 'versionid' }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); if(result.CommonMsg.Status < 300 && result.InterfaceResult){ console.log('Owner[ID]-->' + result.InterfaceResult.Owner.ID); console.log('Owner[Name]-->' + result.InterfaceResult.Owner.Name); for(var i in result.InterfaceResult.Grants){ console.log('Grant[' + i + ']:'); console.log('Grantee[ID]-->' + result.InterfaceResult.Grants[i]['Grantee']['ID']); console.log('Grantee[URI]-->' + result.InterfaceResult.Grants[i]['Grantee']['URI']); console.log('Permission-->'+ result.InterfaceResult.Grants[i]['Permission']); } } } });
Feedback
Was this page helpful?
Chatbot
