SDK Common Result Objects
After you call an API in an instance of the ObsClient class, a common result object will be returned if the exception information parameter is null. The following table lists the object content:
Field |
Type |
Description |
CommonMsg |
Object |
Common information generated after the API calling is complete, including HTTP status code and error code. |
Status |
Number |
HTTP status code. If the value is smaller than 300, the operation succeeds. Otherwise, the operation fails. |
Code |
String |
Error code on the OBS server. If Status is smaller than 300, the value is null. |
Message |
String |
Error description on the OBS server. If Status is smaller than 300, the value is null. |
HostId |
String |
Requested server ID. If Status is smaller than 300, the value is null. |
RequestId |
String |
Request ID returned by the OBS server |
Id2 |
String |
Request ID2 returned by the OBS server |
Indicator |
String |
Detailed error code returned by the OBS server. If Status is smaller than 300, the value is null. |
InterfaceResult |
Object |
Result data generated after the operation is successful. If Status is greater than 300, the value is null. |
RequestId |
String |
Id2 |
String |
Other fields |
For details, see the OBS BrowserJS SDK API Reference. |
Sample code for processing public result objects:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); // Call APIs to perform related operations, for example, downloading an object. obsClient.getObject({ Bucket : 'bucketname', Key : 'objectname', }, function (err, result) { if(!err){ if(result.CommonMsg.Status < 300){ // Obtain the request ID. console.log('RequestId-->' + result.InterfaceResult.RequestId); // Obtain other parameters. console.log('Content-->' + result.InterfaceResult.Content); }else{ // Obtain Code and Message. console.log('Code-->' + result.CommonMsg.Code); console.log('Message-->' + result.CommonMsg.Message); } } });
Feedback
Was this page helpful?
Chatbot
