Help Center/ Object Storage Service/ SDK Reference/ BrowserJS/ FAQs/ How Do I Suspend a Resumable Upload Task?
Updated on 2024-04-26 GMT+08:00
The API for resumable upload supports the suspension of upload tasks. The code example is as follows:
// Create an instance of ObsClient.
var obsClient = new ObsClient({
    // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
    // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    access_key_id: process.env.AccessKeyID,
    secret_access_key: process.env.SecretAccessKey,
    // Replace the example endpoint with the actual one in your case.
    server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
var uploadCheckpoint;
obsClient.uploadFile({
       Bucket : 'bucketname',
       Key : 'objectname',
       SourceFile : document.getElementById('input-file').files[0],
       PartSize : 9 * 1024 * 1024,
       ProgressCallback : function(transferredAmount, totalAmount, totalSeconds){
           // Obtain the upload progresses.
           console.log(transferredAmount * 1.0 / totalSeconds / 1024);
           console.log(transferredAmount * 100.0 / totalAmount);
       ResumeCallback : function(resumeHook, uploadCheckpoint){
           // If the upload is suspended after running for three seconds, the API returns an error.
           setTimeout(function(){
              hook.cancel();
           }, 3000);
           // Record a breakpoint.
           cp = uploadCheckpoint;
}, function(err, result){
    console.error('Error-->' + err);
    // If an error occurs, call the resumable upload API again to continue the upload task.
    if(err){
          UploadCheckpoint : uploadCheckpoint,
           // Reprocess the callback function.
    }else {
         console.log('Status-->' + result.CommonMsg.Status);
         console.log('RequestId-->' + result.CommonMsg.RequestId);
