Performing a Streaming Upload
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Streaming upload uses System.IO.Stream as the data source of an object. You can call ObsClient.PutObject to upload the data streams to OBS. Sample code is as follows:
// Initialize configuration parameters. ObsConfig config = new ObsConfig(); config.Endpoint = "https://your-endpoint"; // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine); string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine); // Create an instance of ObsClient. ObsClient client = new ObsClient(accessKey, secretKey, config); // Upload a stream. try { String str = "Hello OBS"; Stream stream = new MemoryStream(System.Text.Encoding.Default.GetBytes(str)); PutObjectRequest request = new PutObjectRequest() { BucketName = "bucketname", ObjectKey = "objectname", InputStream = stream, }; PutObjectResponse response = client.PutObject(request); Console.WriteLine("put object response: {0}", response.StatusCode); } catch (ObsException ex) { Console.WriteLine("ErrorCode: {0}", ex.ErrorCode); Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage); }
- To upload a large file, you are advised to use multipart upload.
- The content to be uploaded cannot exceed 5 GB.
Feedback
Was this page helpful?
Chatbot
