Help Center/ Object Storage Service/ SDK Reference/ .NET/ Object Upload/ Performing an Asynchronous Upload
Updated on 2024-12-09 GMT+08:00
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.BeginPutObject and ObsClient.EndPutObject to upload an object asynchronously.
This example asynchronously uploads local file localfile to bucket bucketname as object objectname.
Sample code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Upload a file in asynchronous mode.
try
    PutObjectRequest request = new PutObjectRequest()
        BucketName = "bucketname",
        ObjectKey = "objectname",
        FilePath = "localfile",// Path of the local file to be uploaded. The file name must be specified.
    client.BeginPutObject(request, delegate(IAsyncResult ar){
        try
            PutObjectResponse response = client.EndPutObject(ar);
            Console.WriteLine("put object response: {0}", response.StatusCode);
        catch (ObsException ex)
             Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
             Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
    }, null);
    Console.WriteLine("Message: {0}", ex.Message);
