Setting Versioning Status for a Bucket
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.SetBucketVersioning to set the versioning status for a bucket. OBS supports two versioning statuses.
Versioning Status |
Description |
Value in OBS .NET SDK |
Enabled |
VersionStatusEnum.Enabled |
Suspended |
VersionStatusEnum.Suspended |
Sample code:
// Initialize configuration parameters. ObsConfig config = new ObsConfig(); config.Endpoint = "https://your-endpoint"; // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine); string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine); // Create an instance of ObsClient. ObsClient client = new ObsClient(accessKey, secretKey, config); // Set the versioning status. try { SetBucketVersioningRequest request = new SetBucketVersioningRequest(); request.BucketName = "bucketname"; request.Configuration = new VersioningConfiguration(); //Enabling versioning. request.Configuration.Status = VersionStatusEnum.Enabled; SetBucketVersioningResponse response = client.SetBucketVersioning(request); Console.WriteLine("Set bucket version response: {0}", response.StatusCode); } catch (ObsException ex) { Console.WriteLine("ErrorCode: {0}", ex.ErrorCode); Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage); }
Feedback
Was this page helpful?
Chatbot
