Updated on 2025-05-12 GMT+08:00
Listing Multipart Uploads (SDK for Go)
Function
This API lists ongoing multipart uploads.
Ongoing multipart uploads are the multipart uploads that have been initiated but have not been completed or aborted. A maximum of 1,000 multipart uploads can be returned in a response. If there are over 1,000 ongoing tasks satisfying the list criteria, you need to send more requests to query additional multipart uploads.
Restrictions
  • To list multipart uploads, you must be the bucket owner or have the required permission (obs:bucket:ListBucketMultipartUploads in IAM or ListBucketMultipartUploads in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • To list ongoing multipart uploads in a bucket, you must have the ListBucketMultipartUploads permission.
  • The bucket owner can grant others the ListBucketMultipartUploads permission.
Method
func (obsClient ObsClient) ListMultipartUploads(input *ListMultipartUploadsInput) (output *ListMultipartUploadsOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
Yes
Explanation:
Input parameters for listing multipart uploads. For details, see Table 2.
Table 2 ListMultipartUploadsInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Prefix
string
No
Explanation:
Name prefix that the objects in the multipart uploads to be listed must contain
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you specify logs/ as the prefix, the multipart uploads of logs/day1, logs/day2, and logs/day3 will be returned. If you leave this parameter blank, all multipart uploads in the bucket will be returned.
Restrictions:
The value must contain 1 to 1,024 characters.
Default value:
None
MaxUploads
int
No
Explanation:
Maximum number of listed multipart uploads
Restrictions:
If the specified value is greater than 1000, only 1,000 multipart uploads are returned.
Value range:
An integer from 1 to 1000
Default value:
1000
Delimiter
string
No
Explanation:
Object names are grouped by this parameter, which is often used with Prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefixes. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefixes.
Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix, and bbcde is grouped separately into another CommonPrefixes with bbcd as the prefix.
Value range:
Default value:
None
KeyMarker
string
No
Explanation:
Object name after which multipart upload listing begins
Value range:
Value of NextKeyMarker in the response body of the last request
Default value:
None
UploadIdMarker
string
No
Explanation:
Upload ID after which the multipart upload listing begins
Restrictions:
This parameter is valid only when used with KeyMarker. If both parameters are specified, multipart uploads with IDs greater than the specified UploadIdMarker for the specified KeyMarker are listed.
Value range:
The value of NextUploadIdMarker in the response body of the last request
Default value:
None
EncodingType
string
No
Explanation:
Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key.
Value range:
url
Default value:
None. If you leave this parameter blank, encoding is not applied to Key.
Responses
Table 3 List of returned results
Parameter
Type
Description
output
Explanation:
Returned results. For details, see Table 4.
err
error
Explanation:
Error messages returned by the API
Table 4 ListMultipartUploadsOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Bucket
string
Explanation:
Bucket name
Restrictions:
  • A bucket name:
Value range:
The value must contain 3 to 63 characters.
KeyMarker
string
Explanation:
Object name after which multipart upload listing begins. This parameter is consistent with that set in the request.
Value range:
Default value:
None
UploadIdMarker
string
Explanation:
Upload ID after which the multipart upload listing begins, which is consistent with that set in the request
Value range:
The value must contain 1 to 32 characters.
Default value:
None
NextKeyMarker
string
Explanation:
Object name to start with for the next multipart upload listing request. NextKeyMarker is returned when not all the objects are listed. You can set KeyMarker to this value in the next request to list the remaining multipart uploads.
Value range:
Default value:
None
NextUploadIdMarker
string
Explanation:
Upload ID to start with for the next multipart upload listing request. This parameter is used together with NextKeyMarker. NextVersionIdMarker is returned when not all the objects are listed. You can set NextKeyMarker to this value in the next request to list the remaining multipart uploads.
Value range:
Default value:
None
MaxUploads
int
Explanation:
Maximum number of listed multipart uploads, which is consistent with the same parameter in the request
Restrictions:
Value range:
Default value:
1000
IsTruncated
bool
Explanation:
Whether all results are returned in the response
Value range:
  • true: Not all results are returned.
  • false: All results are returned.
Default value:
None
Prefix
string
Explanation:
Prefix that the object names in the multipart uploads to be listed must contain. This parameter is consistent with that set in the request.
Restrictions:
Default value:
None
Delimiter
string
Explanation:
A character used to group object names in multipart uploads, which is consistent with that set in the request. This parameter is often used with Prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefixes. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefixes.
Value range:
Default value:
None
Uploads
[]Upload
Explanation:
List of multipart uploads. For details, see Table 5.
CommonPrefixes
[]string
Explanation:
List of object name prefixes grouped according to the Delimiter parameter (if specified)
Value range:
Default value:
None
EncodingType
string
Explanation:
Value range:
url
Default value:
Table 5 Upload
Parameter
Type
Description
Key
string
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
Default value:
None
UploadId
string
Explanation:
Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8
Value range:
Default value:
None
Initiator
Initiator
Explanation:
Initiator of the multipart upload. For details, see Table 6.
Owner
Owner
Explanation:
Account ID of the object owner. For details, see Table 7.
StorageClass
StorageClassType
Explanation:
Storage class of the object to be uploaded
Value range:
See Table 8.
Default value:
None
Initiated
time.Time
Explanation:
Time when the multipart upload is initiated
Restrictions:
The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z.
Sample code: time.Now().Add(time.Duration(24) * time.Hour)
Default value:
None
Table 6 Initiator
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the initiator
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
DisplayName
string
No
Explanation:
Account name of the initiator
Restrictions:
The account name can contain 6 to 32 characters and must start with a letter. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Default value:
None
Table 7 Owner
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Explanation:
Account (domain) ID of the owner
Value range:
Default value:
None
Table 8 StorageClassType
Constant
Default Value
Description
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Code Examples
This example lists all initiated multipart uploads (that have not yet been completed or aborted) in bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.ListMultipartUploadsInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify the maximum number of multipart uploads that can be listed. 10 is used as an example.
    input.MaxUploads = 10
    // List initiated multipart uploads in the bucket.
    output, err := obsClient.ListMultipartUploads(input)
    if err == nil {
        fmt.Printf("List multipart uploads successful with bucket(%s) !\n", input.Bucket)
        for index, upload := range output.Uploads {
            fmt.Printf("Upload[%d]-OwnerId:%s, UploadId:%s, Key:%s, Initiated:%s\n",
                index, upload.Owner.ID, upload.UploadId, upload.Key, upload.Initiated)
        return
    fmt.Printf("List multipart uploads fail with bucket(%s) !\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
