Obtaining the Region of a Bucket (SDK for Go)
Function
This API returns the region of a bucket.
Restrictions
- To obtain the region of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketLocation in IAM or GetBucketLocation in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) GetBucketLocation(bucketName string) (output *GetBucketLocationOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 3. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Location |
string |
Explanation: Region where a bucket is located Restrictions: If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required. Value range: To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator. Default value: If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default. |
Code Examples
This example returns the region where bucket examplebucket locates.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Specify a bucket name. bucketname := "examplebucket" // Obtain the bucket region. output, err := obsClient.GetBucketLocation(bucketname) if err == nil { fmt.Printf("Get bucket(%s)'s location successful!\n", bucketname) fmt.Printf("RequestId:%s\n", output.RequestId) fmt.Printf("Location:%s\n", output.Location) return } fmt.Printf("Get bucket(%s)'s location fail!\n", bucketname) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
