Help Center/
Object Storage Service/
SDK Reference/
Node.js/
Getting Started (SDK for Node.js)/
Initializing an Instance of ObsClient (SDK for Node.js)
Updated on 2024-11-13 GMT+08:00
Each time you want to send an HTTP/HTTPS request to OBS, you must create an instance of ObsClient. Sample code is as follows:
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); // Use the instance to access OBS. // Close the ObsClient instance. // obsClient.close();
- JavaScript is an asynchronous programming language. Therefore, you cannot call the close method when accessing OBS.
- An ObsClient instance cannot be used again after it is closed by calling obsClient.close.
- For more information, see chapter "Initialization."
- For logging configuration, see Configuring SDK Logging (SDK for Node.js).
- For proxy configuration, see Configuring an SDK Proxy (SDK for Node.js).
Parent topic: Getting Started (SDK for Node.js)
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
