Help Center/
Object Storage Service/
SDK Reference/
Node.js/
Getting Started (SDK for Node.js)/
Listing Objects (SDK for Node.js)
Updated on 2024-11-13 GMT+08:00
After objects are uploaded, you may want to view the objects contained in a bucket. Sample code is as follows:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function listObjects() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", }; // List objects in a bucket. const result = await obsClient.listObjects(params); if (result.CommonMsg.Status <= 300) { console.log("List objects under the bucket(%s) successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); for (let j = 0; j < result.InterfaceResult.Contents.length; j++) { const val = result.InterfaceResult.Contents[j]; console.log('Content[%d]-OwnerId:%s, ETag:%s, Key:%s, LastModified:%s, Size:%d', j, val.Owner.ID, val.ETag, val.Key, val.LastModified, val.Size); }; return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; listObjects(); |
- In the sample code, 1000 objects will be listed, by default.
- For more information, see Listing Objects.
Parent topic: Getting Started (SDK for Node.js)
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
