Updated on 2025-05-20 GMT+08:00
Configuring a Bucket ACL (SDK for Node.js)
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources.
For more information, see ACLs.
This API modifies a bucket ACL.
Restrictions
Method
ObsClient.setBucketAcl(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
ACL
AclType
No
Explanation:
Pre-defined ACL.
Restrictions:
You must specify either ACL or the combination of Owner and Grants.
Value range:
See Table 2.
Default value:
None
Owner
Owner
No
Explanation:
Bucket owner
Restrictions:
  • Owner and Grants must be used together, and they cannot be used with ACL.
  • You must specify either ACL or the combination of Owner and Grants.
Value range:
See Table 3.
Default value:
None
Grants
Grant[]
No
Explanation:
Grantees and permissions
Restrictions:
Value range:
See Table 4.
Default value:
None
Table 2 AclType
Constant
Default Value
Description
ObsClient.enums.AclPrivate
private
Private read and write
A bucket or object can only be accessed by its owner.
ObsClient.enums.AclPublicRead
public-read
Public read and private write
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket.
If this permission is granted on an object, everyone can obtain the content and metadata of the object.
ObsClient.enums.AclPublicReadWrite
public-read-write
Public read and write
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks.
ObsClient.enums.AclPublicReadDelivered
public-read-delivered
Public read on a bucket as well as the objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions and read the content and metadata of objects in the bucket.
NOTE:
AclPublicReadDelivered does not apply to objects.
ObsClient.enums.AclPublicReadWriteDelivered
public-read-write-delivered
Public read and write on a bucket as well as the objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
NOTE:
AclPublicReadWriteDelivered does not apply to objects.
ObsClient.enums.AclBucketOwnerFullControl
bucket-owner-full-control
If this permission is granted on an object, only the bucket and object owners have the full control over the object.
By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this policy to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets the bucket-owner-full-control policy for object x, user B then has the control over object x.
Table 3 Owner
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the owner
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID? (SDK for Node.js).
Default value:
None
DisplayName
string
No
Explanation:
Account name of the owner
Default value:
None
Table 4 Grant
Parameter
Type
Mandatory (Yes/No)
Description
Grantee
Grantee
Explanation:
Grantee information. For details, see Table 5.
Permission
PermissionType
Explanation:
Granted permission
Value range:
See Table 8.
Default value:
None
Delivered
boolean
No
Explanation:
Whether the ACL of the bucket applies to its objects
Value range:
  • true: The ACL of the bucket applies to its objects.
  • false: The ACL of the bucket does not apply to its objects.
Default value:
None
Table 5 Grantee
Parameter
Type
Mandatory (Yes/No)
Description
Type
string
Explanation:
Grantee type
Value range:
See Table 6.
Default value:
None
ID
string
Yes if this parameter is used as a request parameter and Type is set to a user
Explanation:
Account (domain) ID of the grantee.
Value range:
Default value:
None
Name
string
No if used as a request parameter
Explanation:
Account name of the grantee
Restrictions:
  • The account name cannot contain full-width characters.
  • The account name starts with a letter.
  • The account name contains 6 to 32 characters.
  • The account name contains only letters, digits, hyphens (-), or underscores (_).
Default value:
None
URI
GroupUriType
Yes if this parameter is used as a request parameter and Type is set to a group
Explanation:
Authorized user group
Value range:
See Table 7.
Default value:
None
Table 6 GranteeType
Constant
Description
Group
Grants permissions to user groups.
CanonicalUser
Grants permissions to individual users.
Table 7 GroupUriType
Constant
Default Value
Description
ObsClient.enums.GroupAllUsers
AllUsers
All users.
ObsClient.enums.GroupAuthenticatedUsers
AuthenticatedUsers
Authorized users. This constant is deprecated.
ObsClient.enums.GroupLogDelivery
LogDelivery
Log delivery group. This constant is deprecated.
Table 8 PermissionType
Constant
Default Value
Description
ObsClient.enums.PermissionRead
READ
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
ObsClient.enums.PermissionWrite
WRITE
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not applicable to objects.
ObsClient.enums.PermissionReadAcp
READ_ACP
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
ObsClient.enums.PermissionWriteAcp
WRITE_ACP
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
ObsClient.enums.PermissionFullControl
FULL_CONTROL
A grantee with this permission for a bucket has PermissionRead, PermissionWrite, PermissionReadAcp, and PermissionWriteAcp permissions for the bucket.
A grantee with this permission for an object has PermissionRead, PermissionReadAcp, and PermissionWriteAcp permissions for the object.
Responses
Table 9 Responses
Type
Description
Table 10
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 10.
Table 10 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 11.
InterfaceResult
Table 12
Explanation:
Results outputted for a successful call. For details, see Table 12.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 11 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 12 BaseResponseOutput
Parameter
Type
Description
RequestId
string
Explanation:
Code Examples: Setting a Pre-defined ACL When Creating a Bucket
This example sets a pre-defined ACL (private read and write) when creating a bucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an ObsClient instance.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function createBucket() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify the region where the bucket is to be created. The region must be the same as that in the passed endpoint. ap-southeast-1 is used in this example.
      // Location: "ap-southeast-1",
      // Specify the ACL. obs.AclPrivate is used as an example.
      ACL: obsClient.enums.AclPrivate,
    // Create a bucket.
    const result = await obsClient.createBucket(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Create bucket(%s) successful!", params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
createBucket();
Code Examples: Setting a Pre-defined ACL for a Bucket
This example sets an ACL (private) for bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
// Create an instance of ObsClient.
  //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
async function setBucketAcl() {
  try {
    const params = {
      // Set the bucket ACL to be private.
    // Set the bucket ACL.
    const result = await obsClient.setBucketAcl(params);
      console.log("Set bucket(%s)'s acl successful!", params.Bucket);
      return;
  } catch (error) {
    console.log(error);
setBucketAcl();
Code Examples: Setting an ACL for a Bucket Directly
This example sets an ACL to allow all users to read from bucket examplebucket but only allow user 0a03f5833900d3730f13c00f49d5exxx to write to the bucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
  try {
    const params = {
      // Specify the bucket owner ID. ownerid is used in this example.
      Owner: { ID: 'ownerid' },
      Grants: [
        // Grant the public-read permission to all users.
        { Grantee: { Type: 'Group', URI: obsClient.enums.GroupAllUsers  }, Permission: obsClient.enums.PermissionRead },
          // Grant the write permission to a specific user. In this example, the user ID is 0a03f5833900d3730f13c00f49d5exxx.
        { Grantee: { Type: 'CanonicalUser', ID: '0a03f5833900d3730f13c00f49d5exxx' }, Permission: obsClient.enums.PermissionWrite },
      return;
  } catch (error) {
    console.log(error);
setBucketAcl();
