Updated on 2024-11-13 GMT+08:00
SDK Common Results (SDK for Node.js)
After you call an API in an instance of the ObsClient class, a common result object will be returned if no exception is thrown. The following table lists the fields of the object:
Parameter
Type
Description
CommonMsg
Object
Common information generated after the API is called, including HTTP status code and error code.
Status
Number
HTTP status code. If the value is smaller than 300, the operation succeeds. Otherwise, the operation fails.
Code
String
Error code returned by the OBS server. If Status is smaller than 300, the value is null.
Message
String
Error description returned by the OBS server. If Status is smaller than 300, the value is null.
HostId
String
Requested Server ID. If Status is smaller than 300, the value is null.
RequestId
String
Request ID returned by the OBS server
Id2
String
Request ID2 returned by the OBS server
Indicator
String
Detailed error code returned by the OBS server. If Status is smaller than 300, the value is null.
InterfaceResult
Object
Result data generated after the operation is successful. If Status is greater than 300, the value is null.
RequestId
String
Request ID returned by the OBS server.
Id2
String
Other fields
For details, see the Response area in the corresponding section.
Sample code:
// Import the OBS library.
// Use npm to install the client.
var ObsClient = require('esdk-obs-nodejs');
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
    //Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    access_key_id: process.env.ACCESS_KEY_ID,
    secret_access_key: process.env.SECRET_ACCESS_KEY,
    //CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
    server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
// Call APIs to perform operations, such as downloading an object.
obsClient.getObject({
       Bucket : 'bucketname',
       Key : 'objectname',
}, (err, result) => {
       if(!err){
              if(result.CommonMsg.Status < 300){
                    // Obtain RequestId.
                     console.log('RequestId-->' + result.InterfaceResult.RequestId);
                     // Obtain other parameters.
                     console.log('Content-->' + result.InterfaceResult.Content.toString());
              }else{
                     // Obtain Code and Message.
                     console.log('Code-->' + result.CommonMsg.Code);
                     console.log('Message-->' + result.CommonMsg.Message);
