Updated on 2025-02-07 GMT+08:00
Uploading a Part (SDK for Node.js)
Function
After a multipart upload is initiated, this API uploads a part to a specified bucket. In the upload request, the multipart upload ID must be included.
When uploading a part, you must specify its upload ID and part number. You can select any part number between 1 and 10000. A part number uniquely identifies a part and its location in the object you are uploading. If the number of an uploaded part is used to upload a new part, the uploaded part will be overwritten. Whenever you upload a part, OBS returns the ETag header in the response. For each part upload, you must record the part number and the ETag value. These values are required in subsequent requests to complete a multipart upload.
Restrictions
  • To assemble parts, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
  • Except for the last part uploaded, the other parts range from 0 to 5 GB, and the last part ranges from 100 KB to 5 GB. Part sizes will not be verified during upload because whether an uploaded part is the last one cannot be determined. Their sizes will be verified when being assembled.
  • Each part is numbered from 1 to 10000.
  • The minimum part size supported by an OBS 3.0 bucket is 100 KB, and that supported by an OBS 2.0 bucket is 5 MB. You are advised to perform the multipart upload on OBS 3.0 buckets.
Method
ObsClient.uploadPart(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
PartNumber
number
Yes
Explanation:
Part number.
Restrictions:
None
Value range:
An integer ranging from 1 to 10000.
Default value:
None
UploadId
string
Yes
Explanation:
Multipart upload ID, which is generated by initiating a multipart upload.
Restrictions:
None
Value range:
The value must contain 32 characters,
for example, 000001648453845DBB78F2340DD460D8.
Default value:
None
ContentMD5
string
No
Explanation:
Base64-encoded MD5 value of the data to be uploaded. It is used for the OBS server to verify data integrity.
Restrictions:
Base64-encoded, 128-bit MD5 value of the request body.
Value range:
Base64-encoded, 128-bit MD5 value of the request body calculated based on the RFC 1864 standard.
Example: n58IG6hfM7vqI4K0vnWpog==
Default value:
None
Body
string | stream.Readable
No
Explanation:
Data stream of the object to be uploaded.
Restrictions:
The content size in a single upload ranges from 0 to 5 GB.
Value range:
None
Default value:
None
SourceFile
string
No
Explanation:
Source file path of the object to be uploaded
Restrictions:
  • The content size in a single upload ranges from 0 to 5 GB.
  • Body and SourceFile cannot be used together.
  • If both Body and SourceFile are left blank, the size of the uploaded object is 0 bytes.
  • Offset, PartSize, and SourceFile can be used together to specify part of the source file to upload.
Value range:
None
Default value:
None
Offset
number
No
Explanation:
Start offset of a part in the source file.
Restrictions:
Value range:
A non-negative integer smaller than the size of the object to be uploaded, in bytes
Default value:
0
PartSize
number
No
Explanation:
Part size.
Restrictions:
Value range:
The value ranges from 100 KB to 5 GB, in bytes.
Default value:
102400
SseKms
string
Yes when SSE-KMS is used
Explanation:
SSE-KMS is used for encrypting objects on the server side.
Restrictions:
Currently, only KMS is supported.
Value range:
kms
Default value:
None
SseKmsKey
string
No
Explanation:
ID of the KMS master key when SSE-KMS is used.
Restrictions:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Value range:
None
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is not a default master key, OBS will create one and use it.
SseC
string
Yes when SSE-C is used
Explanation:
SSE-C is used for encrypting objects on the server side.
Restrictions:
Only AES256 is supported.
Value range:
AES256
Default value:
None
SseCKey
string
Explanation:
Key used for encrypting the object when SSE-C is used
Restrictions:
A Base64-encoded, 256-bit value, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=
Value range:
None
Default value:
None
Responses
Table 2 Responses
Type
Description
Table 3
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results outputted for a successful call. For details, see Table 5.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 4 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 UploadPartOutput
Parameter
Type
Description
RequestId
string
Explanation:
ETag
string
Explanation:
Base64-encoded, 128-bit MD5 value of an object. The ETag is a unique identifier for the object's contents, used to determine if the object has been updated. For example, if the ETag value is A when an object is uploaded and becomes B when the object is downloaded, this indicates the contents of the object were changed. The ETag reflects changes of an object, not of the metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Code Examples
This example uploads a part to bucket examplebucket in a specified multipart upload (uploadId) of object example/objectname.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function uploadPart() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify the object. example/objectname is used in this example.
      Key: "example/objectname",
      // Specify the ID of the multipart upload.
      UploadId: "0000000xxxxxxxx",
      // Specify the part number (1 in this example) of the part to upload. The part number is an integer ranging from 1 to 10000.
      PartNumber: 1,
      // Specify the source file path of the part to upload (localfile in this example).
      SourceFile: "localfile",
      // Specify the part size (5 MB in this example), in bytes.
      PartSize: 5 * 1024 * 1024,
      // Specify the offset of the part (0 in this example).
      Offset: 0
    // Upload the part.
    const result = await obsClient.uploadPart(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Upload part(%d) successful with bucket(%s) and object(%s)!", params.PartNumber, params.Bucket, params.Key);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      console.log("ETag: %s", result.InterfaceResult.ETag);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
uploadPart();
