Updated on 2025-05-09 GMT+08:00
Batch Deleting Objects (SDK for Python)
Function
This API deletes objects in a batch from a specific bucket. Deleted objects cannot be restored.
OBS does not involve folders like in a file system. All elements stored in OBS buckets are objects. A folder you see on the console or other tools in OBS is essentially an object whose size is 0 and whose name ends with a slash (/). To delete a folder, you need to list all objects whose names are prefixed with the folder name and then call the batch deletion API.
In a batch delete operation, OBS concurrently deletes the specified objects and returns the deletion result of each object.
Restrictions
  • To delete objects in a batch, you must be the bucket owner or have the required permission (obs:object:DeleteObject in IAM or DeleteObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • If versioning is not enabled for a bucket, deleted objects cannot be recovered.
  • A maximum of 1,000 objects can be deleted at a time. If you send a request for deleting more than 1,000 objects, OBS returns an error message.
  • After concurrent tasks are assigned, if an internal error occurs during cyclic deletion of multiple objects, an object may be deleted in the index data but still exist in the metadata.
Method
ObsClient.deleteObjects(bucketName, deleteObjectsRequest, extensionHeaders)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
DeleteObjectsRequest
Yes
Explanation:
Request parameters of deleting objects in a batch For details, see Table 2.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Table 2 DeleteObjectsRequest
Parameter
Type
Mandatory (Yes/No)
Description
quiet
bool
No
Explanation:
Response mode to the request for deleting objects in a batch
Value range:
  • False: The detailed mode. Results of both successful and failed deletions are returned.
  • True: The quiet mode. Only results of failed deletions are returned.
Default value:
False
objects
list of Object
Yes
Explanation:
List of objects to be deleted. For details, see Table 3.
Default value:
None
encoding_type
str
No
Explanation:
Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key.
Value range:
url
Default value:
None. If you leave this parameter blank, encoding is not applied to Key.
Table 3 Object
Parameter
Type
Mandatory (Yes/No)
Description
key
str
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
versionId
str
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9
Value range:
The value must contain 32 characters.
Default value:
None. If this parameter is left blank, the latest version of the object is deleted.
encoding_type
str
No
Explanation:
Encoding type for some elements in the response. If delimiter, key_marker, prefix, nextKeyMarker, and key contain control characters that are not supported by the XML 1.0 standard, you can set encoding_type to encode delimiter, key_marker, prefix (including the Prefix in commonPrefixes), nextKeyMarker, and key in the response.
Value range:
Type: string. Value option: url
Responses
Table 4 List of returned results
Type
Description
GetResult
Explanation:
SDK common results
Table 5 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
Table 6 GetResult.body
GetResult.body Type
Description
DeleteObjectResponse
Explanation:
Response results of the request for deleting objects in a batch For details, see Table 7.
Table 7 DeleteObjectResponse
Parameter
Type
Description
deleteMarker
bool
Explanation:
Whether the deleted object is a delete marker
Value range:
  • true: The deleted object is a delete marker.
  • false: The deleted object is not a delete marker.
Default value:
false
versionId
str
Explanation:
Value range:
Default value:
Code Examples
This example deletes objects objectkey1 and objectkey2 from bucket examplebucket in a batch.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
from obs import ObsClient
import os
from obs import DeleteObjectsRequest
from obs import Object
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    # Specify the objects to be deleted in a batch.
    object1 = Object(key='objectkey1', versionId=None)
    object2 = Object(key='objectkey2', versionId=None)
# Specify encoding_type when the object name contains special characters.
    encoding_type = 'url'
    bucketName = "examplebucket"
    # Batch delete the objects.
    resp = obsClient.deleteObjects(bucketName, DeleteObjectsRequest(quiet=False, objects=[object1, object2],
        encoding_type=encoding_type))
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Delete Objects Succeeded')
        print('requestId:', resp.requestId)
        if resp.body.deleted:
            index = 1
            for delete in resp.body.deleted:
                print('delete[' + str(index) + ']')
                print('key:', delete.key, ',deleteMarker:', delete.deleteMarker, ',deleteMarkerVersionId:',
                      delete.deleteMarkerVersionId)
                print('versionId:', delete.versionId)
                index += 1
        if resp.body.error:
            index = 1
            for err in resp.body.error:
                print('err[' + str(index) + ']')
                print('key:', err.key, ',code:', err.code, ',message:', err.message)
                print('versionId:', err.versionId)
                index += 1
    else:
        print('Delete Objects Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
This example deletes all objects prefixed with test/ in bucket examplebucket.
In the example below, if the value of prefix is an empty string or NULL, all files in the bucket will be deleted.
import os
import traceback
try:
    # Specify the folder to be deleted.
    prefix = 'test/'
    # Specify the maximum number of objects to be listed at a time. 1000 is used in this example.
    max_num = 1000
    mark = None
    index = 1
    failed_list = []
    while True:
        resp = obsClient.listObjects(bucketName=bucketName, prefix=prefix, marker=mark, max_keys=max_num,
                                     encoding_type='url')
            need_to_delete_objects = [Object(key=i["key"], versionId=None) for i in resp.body["contents"]]
            del_resp = obsClient.deleteObjects(bucketName,
                                               DeleteObjectsRequest(False, need_to_delete_objects, encoding_type="url"))
            for delete in del_resp.body.deleted:
                print("Successfully deleted %s " % delete.key)
                index += 1
            if del_resp.body.error:
                for err in del_resp.body.error:
                    print("Failed to delete %s" % err.key)
                    failed_list.append(err.key)
            if resp.body.is_truncated is True:
                mark = resp.body.next_marker
            else:
                break
        else:
            break
    print("Total deleted %s objects" % index)
    for i in failed_list:
        print("Failed to delete %s, please try again" % i)
except:
