Updated on 2025-05-09 GMT+08:00
Copying a Part (SDK for Python)
Function
This API copies a part to a specified bucket. This request must contain the multipart upload ID.
After creating a multipart upload, you can specify the upload ID and upload parts for the multipart upload. Alternatively, you can call this API to copy part or all of an uploaded object as a part.
Assume that you copy a source object and save it as part1. If there is already a part1 before the copy, the new part1 will overwrite the existing part1. Then, only the new part1 can be listed and the old part1 is deleted. Therefore, when using this API, ensure that the target part does not exist or is no longer used, to avoid accidental deletion. The source object keeps unchanged in the entire copy process.
Restrictions
  • To copy a part, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • You cannot determine whether a part copy is successful only based on status_code in the HTTP header returned. A 200 response indicates that the server has received the request and starts to process the request. Only when the response body contains ETag, the copy is successful, or the copy fails.
Method
ObsClient.copyPart(bucketName, objectKey, partNumber, uploadId, copySource, copySourceRange, destSseHeader, sourceSseHeader, extensionHeaders)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Target bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
objectKey
str
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
NOTE:
The object URL is in the following format: https://Bucket name.Domain name/Folder directory level/Object name. If this object is stored in the root directory of the bucket, its URL does not contain the folder directory level.
partNumber
int
Yes
Explanation:
Part number
Value range:
[1,10000]
Default value:
None
uploadId
str
Yes
Explanation:
Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8
Value range:
The value must contain 32 characters.
Default value:
None
copySource
str
Yes
Explanation:
Parameter used to specify the source bucket, source object, and source object version ID which can be left blank. It is in the format of SourceBucketName/SourceObjectName?versionId=SourceObjectVersionId.
Restrictions:
  • A bucket name:
  • An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
Default value:
None
copySourceRange
str
No
Explanation:
Copy source range. For example, 0-999 indicates the range is from byte 1 to byte 1,000.
Value range:
Value range: 0 to the object length minus 1. Format: x-y, indicating the range is from byte x+1 to byte y+1
Restrictions:
The upper limit of range is the length of the object minus 1. If the specified value exceeds this limit, the length of the object minus 1 is used.
Default value:
None
destSseHeader
SseCHeader or SseKmsHeader
No
Explanation:
Server-side encryption header used for encrypting the target object. For details, see Table 2 or Table 3.
sourceSseHeader
SseCHeader
No
Explanation:
Server-side decryption header used for decrypting the source object. For details, see Table 2.
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Table 2 SseCHeader
Parameter
Type
Mandatory (Yes/No)
Description
encryption
str
Yes
Explanation:
SSE-C used for encrypting objects
Value range:
AES256
Default value:
None
key
str
Yes
Explanation:
Key used in SSE-C encryption. It corresponds to the encryption method. For example, if encryption is set to AES256, the key is calculated using the AES-256 algorithm.
Value range:
Default value:
None
Table 3 SseKmsHeader
Parameter
Type
Mandatory (Yes/No)
Description
encryption
str
Yes
Explanation:
SSE-KMS used for encrypting objects
Value range:
kms
Default value:
None
key
str
No
Explanation:
Master key used in SSE-KMS
Value range:
The following two formats are supported:
  • regionID:domainID:key/key_id
  • key_id
In the preceding formats:
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is no such a default master key, OBS will create one and use it by default.
Responses
Table 4 List of returned results
Type
Description
GetResult
Explanation:
SDK common results
Table 5 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
Table 6 GetResult.body
GetResult.body Type
Description
CopyPartResponse
Explanation:
Response to the request for copying a part. For details, see Table 7.
Table 7 CopyPartResponse
Parameter
Type
Description
etag
str
Explanation:
Base64-encoded 128-bit MD5 digest of a part. ETag is the unique identifier of the part content. It can be used to determine whether the part content is changed.
Value range:
Default value:
None
lastModified
str
Explanation:
Time when the last modification was made to the object
Restrictions:
The time must be in the GMT format, for example, Wed, 25 Mar 2020 02:39:52 GMT.
Default value:
None
sseKms
str
Explanation:
SSE-KMS is used for encrypting objects on the server side.
Value range:
kms
Default value:
None
sseKmsKey
str
Explanation:
ID of the KMS master key when SSE-KMS is used
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
Default value:
sseC
str
Explanation:
Algorithm used to encrypt and decrypt objects with SSE-C
Value range:
AES256
Default value:
None
sseCKeyMd5
str
Explanation:
MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key.
Restrictions:
The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Default value:
None
Code Examples
This example copies parts from one bucket to another.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName = "examplebucket"
    objectKey = "objectname"
    # Specify the part number, which ranges from 1 to 10,000
    partNumber = "your partNumber"
    # Specify the ID of the multipart upload.
    uploadId = "your uploadid"
    # Specify the source bucket, source object, and source object version ID (optional). The format is source-bucket-name/source-object-name?versionId=source-object-versionId.
    copySource = 'sourcebucketname/sourceobjectkey'
    # [Optional] Specify the copy scope in the format of x-y. Value range: [0, source-object-length – 1].
    # copySourceRange = '0-15'
    # Copy the part to the specified bucket using the multipart upload ID.
    resp = obsClient.copyPart(bucketName, objectKey, partNumber, uploadId, copySource)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Copy Part Succeeded')
        print('requestId:', resp.requestId)
        print('etagValue:', resp.body.etagValue)
        print('modifiedDate:', resp.body.modifiedDate)
    else:
        print('Copy Part Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
