Updated on 2025-04-02 GMT+08:00
row_format
Syntax
ROW FORMAT DELIMITED
[FIELDS TERMINATED BY separator]
[COLLECTION ITEMS TERMINATED BY separator]
[MAP KEYS TERMINATED BY separator] [LINES TERMINATED BY separator]
[NULL DEFINED AS separator]
| SERDE serde_name [WITH SERDEPROPERTIES (property_name=property_value, property_name=property_value, ...)]
Description
  • separator indicates the separator or substitute character in the syntax. Only the CHAR type is supported.
  • FIELDS TERMINATED BY specifies the delimiter of field levels in a table. Only the CHAR type is supported.
  • COLLECTION ITEMS TERMINATED BY specifies the delimiter of the set level. Only the CHAR type is supported.
  • MAP KEY TERMINATED BY specifies the separator between the key and value in the MAP type. Only the CHAR type is supported.
  • LINES TERMINATED BY indicates the separator between lines. Only \n is currently supported.
  • The NULL DEFINED AS clause can be used to specify the NULL format.
  • The SERDE serde_name [WITH SERDEPROPERTIES (property_name=property_value, property_name=property_value, ...)] You can use the following statement to convert the NULL value to an empty string.
    ROW FORMAT SERDE 'org.apache.hadoop.hive.serde2.lazy.LazySimpleSerDe' with serdeproperties('serialization.null.format' = '')
