Help Center/
Cloud Service Engine/
User Guide/
Nacos Engines/
Managing Nacos Engines/
Deleting a Nacos Engine
Updated on 2025-09-19 GMT+08:00
You can delete a Nacos engine if it is no longer used. Deleted engines cannot be restored. Exercise caution when performing this operation. You can delete Nacos engines in the following states:
- Available
- Unavailable
- Creation failed
- Resizing failed
- Upgrade failed
- Unknown
- Log in to CSE.
- In the left navigation pane, choose Registry/Configuration Center.
- Click More > Delete in the Operation column of the target Nacos engine instance. Alternatively, click the target Nacos engine, click Delete in the upper right corner on the Basic Information page, and enter DELETE and click OK in the displayed dialog box.
If the deletion fails, click Force Delete.
Parent topic: Managing Nacos Engines
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
